Question about Sony Ericsson K850i Mobile Phone
How cold i get rid of the extra noise when my
How could i get rid of the extra noise when my playlist is play.its just like the sound of my computer when my cp gets a message. thank you
NANO 7TH GEN. WILL NOT PLAY THE PLAYLIST CHOSEN
Sounds like it might have got water/moisture in it.
tryi drying it out.
Sep 07, 2014 | Apple Ipod Nano 16gb Mp3 Player 7th...
Haier a600 laptop
Uninstall the windows 7. I hear this type of issue all the time.
Mar 24, 2017 | Intel Computers & Internet
Haier a600 laptop
Try updating the drivers with "Driverpacks solution" :
(It's free)
Download the Driverpacks SOlution DVD via torrent :
http://drp.su/
And run it.
This will tell you if you need to update any drivers.
Apr 29, 2014 | Intel Computers & Internet
Yamaha DGX 640 - keys make odd sound
I don't think that is correctable; if it is under warranty, have it repaired or replaced. The yamaha keyboards are great when they work partly because they use sampled sounds; getting extra sounds indicates a bad chip.
May 07, 2017 | Yamaha DGX-640 Walnut 88-Key Keyboard...
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How do you creait a playlist
You must first Rip your albums or Mix CD's to your Xbox, insert an album and click on Rip CD to save it to your Hard Drive, play an album and click on edit or save playlist below the play/stop/forward/ buttons, and get rid of songs you don't want if needed. While playing that album still, back out with the red "b" button on your controller and back up until you are back at albums, now click on it, select another album, and choose "add to current playlist" or "add to playlist" and it will now stack that album on the bottom of the first. Again you can edit and delete or organize songs, then save playlist. Now you can name it and when you go to saved playlists instead of Albums, it will be there. Anymore trouble, please email me at xxsodasipperxx@yahoo.com
Jul 09, 2010 | Microsoft Xbox 360 Console
How do i create different playlists in my sandisk sansa clip. It will play all it will play albums. I have tried to drag a playlist from the lap top windows media player but it says it needs converting to...
1) Open the Sansa in 'My Computer'
2) Double click on the 'Playlist' folder
3) Drag the music you want from the computer into the 'Playlist2_bing.gif' folder
4) Highlight all the files (or the files you want)
5) Right click
6) On the menu that pops up click "Create Playlist" - on my computer it's the very first option, in bold
7) Playlist will be created in the 'Playlist' folder
8) Name it whatever you want and enjoy!!
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
How can i delet a song from iphone
If you want to delete music from iPhone, you can take fully advantage of iTunes. After you purchased songs in iTunes Store on iPhone, your iTunes will also save the purchase history, so you don't have to worry about losing the purchased music files. When you connect iPhone to computer with USB cable, iTunes will launch automatically and recognize your iPhone. You can create a new playlist which contains only the music you need, and then sync it to your iPhone. By doing this, you can remove the unwanted music from iPhone.
  1. Click the iPhone icon at the upper left corner.
  2. Choose Music in the left sidebar.
  3. Check Sync Music choose Selected playlists, artists, albums and genres.
  4. Select the playlist which only contains the songs you need. Then click Sync.
delet-song-from-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg http://www.leawo.org/tutorial/how-to-delete-multiple-songs-from-iphone.html
Oct 21, 2009 | Apple iPhone 3G
Buzzing Noise in Sound Studio
hi, check all cables,clean connections. i have had these kind of problems in the past. also coulb be ground loop!? hope this is helpful.glen
Feb 15, 2009 | Apple Griffin iMic External Sound System
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Sony Ericsson K850i  Mobile Phone Logo
12 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
