Question about Canon PowerShot S3 IS Digital Camera
Inoperable When click camera "on", the lens protrudes only slightly, goes no further and I cannot see an image either through viewfinder or screen; the orange indicator light does not illuminate. Sometimes I hear the camera motor working, but nothing happens with the lens.. When I press "off", camera recedes normally. When I move the lever to view, green light illuminates and I'm able to view previous photos normally. I would greatly appreciate response promptly, since there are some beautiful shots I want to take after a snowfall now. Thanks.
  • 2,985 Answers
The Zoom mechanizim is faulty- this is a shop repair job.
The other possible cause is failing or incorrect battery type.
Either will not deliver enough power to operate the lens.
So check battery condition/type.
IF OK Check Canon for repair/replacement[if still with Warranty]
Posted on Dec 21, 2007
When i take a picture although i centralise an object in the centre if the screen, when the shot is taken it moves downwards and off centre? why is this?
I presume that you're using the optical viewfinder and taking close-up photos.
If so, then your camera is fine but you are making a simple mistake. What's happening is called "parallax error". The viewfinder lens does not see exactly the same view as the camera lens because it's slightly higher and off to one side. For most subjects greater than a few feet away the error is insignificant, but for close ups it becomes a problem. Many optical viewfinders of your type will include framing lines. These show the approximate image which will be taken at distances of more than a few feet, and may have a second set of stubby lines to show where the image will be cut off during close-ups.
Your fix is to simply be aware of parallax error and allow for it when composing your images.
I hope that this has answered your question; if so then please take a moment to rate my reply. If it hasn't then please add a comment with any additional detail you think will help and I'll try again when I'm next online.
Mar 10, 2011 | Canon PowerShot A300 Digital Camera
1. READ YOUR CAMERA MANUAL before taking any photographs.
2. Check your batteries. Make sure to either recharge or replace them if you haven't used your camera as yet or for an extended period.
3. Insert your storage media card in the appropriate slot. If you forget to insert your media card, you'll get a "No Card" message.
4. Remove the lens cap.
5. Turn the camera on by either an on-off switch or a sliding lens cover.
6. Turn off the LCD. (See your camera manual for instructions)
7. Make sure your camera is set for automatic mode. Set the image quality to the size image desired-HQ (high quality) or less (to take more pictures on the same card).
8. Bring the camera up to your eye and look through the viewfinder. Positioning the target mark in the center of the viewfinder on your subject will assure that it will be in focus.
9. Push the zoom lever toward W (wide angle) to shoot wide-angle shots or push it toward the T (telephoto) to zoom in.
10. Press the shutter button half way down gently and confirm that the green light next to the viewfinder is illuminated.
11. Press the shutter button all the way down. You'll hear a beep when you take a picture. Wait until the green light stops flashing before taking another one. Remember, digital cameras have a slight delay that traditional cameras don't since it takes a second to save the image to your camera's storage media card.
12. Turn off the camera. Your new photograph should appear on your camera's LCD screen.
1. Use the viewfinder to compose your photograph, not the LCD screen, which will severely drain your battery power. Use your LCD screen only when shooting close-up photographs.
2. Hold your camera steady. Sometimes, the least amount of movement will cause your photo to be slightly blurred. Purchase a very small tripod so that you can provide extra stability for your camera. Also, if there isn't enough light (indoors or outdoors), make sure to use your camera's flash.
3. Experiment with your camera's features and take notes so that you can learn what works for you. Do this before you plan to use it for an important family event or trip.
Dec 15, 2010 | Cameras
My canon xsi will come out "focused" but when i look through my view finder thing- it is not in focus. do you know what could be wrong?
The viewfinder image focusses onto the ground glass viewfinder screen; your viewfinder image will therefore be out of focus if the screen has moved up or down in relation to where it should be.
Check that the screen is seated properly by removing the lens and looking at the roof of mirror box in the camera body. Usually the screen will have dropped down very slightly and it's held in place by clips to the front and rear. The rear clip is fixed, the front one is a spring clip. Avoid using bare fingers when you manipulate the screen and do not use metal or hard plastic tools on it.
Oct 09, 2010 | Canon EOS Rebel XSi Digital Camera
Image in viewfinder slightly unfocused, photo clear.
Either your viewfinder needs to be cleaned or your camera needs to be cleaned. Most of the time it is the mirror in the camera that is causing this issue and cleaning it will make everything better.
May 30, 2010 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Camera partially inoperable
I suspect the problem is with the batteries. I advise buying new ones.
Dec 20, 2007 | Canon PowerShot S3 IS Digital Camera
Is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Sep 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Can't see whole image thru viewfinder when len is on
Your camera either has no focusing screen or the screen is dislodged. Remove lens and look above the mirror : looks like frosty glass.
Jun 05, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Wierd Images in Viewfinder and Photos
sounds like ccd sensor faulty.the only thing you can try as you say fault happened when lens got jammed is to reset camera by removing batteries for a few secs and reinserting,if this does not work will have to go to service.,
May 11, 2007 | Canon PowerShot S1 IS Digital Camera
Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
