Question about Clarion ADX5255
Screen doesnt lite up, everything else works - Clarion ADX5255
It powers on but the screen does not turn on.never has worked since we bought it. called the teck service said that not possible so my buddy gave up on it.I put a new battery in it green lite comes on but...
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Jan 21, 2011 | Aqua Vu Scout SRT Fishfinders
DS lite screen
Hahahahaha that is how it works but if you go to the little DS at the bottom of the touch screen and tap it there will be a fixer manual use it and when you are done the system will shut off and just turn it on again and also the touch screen is the most important thing on your ds so keep it scratchless and clean! On some games the top screen is an important thing and somtimes it doesnt show anything
Mar 02, 2009 | Nintendo DS Lite Console
My Nintendo DS lite doesnt turn on
Maybe the baterry doesnt work you could try to buy a new one because at somepoint batteries dont work anymore that happened to me.
Jan 16, 2009 | Nintendo DS Lite Console
My touch screen isnt working!!!!!!!!
I have 10 brand new touch screens here, I can replace your screen and get you going again.
This is a common problem. and it will have to be replaced before it will work again.
Thanks,
ninja_freak318@hotmail.com
Dec 26, 2008 | Nintendo DS Lite Console
Ds touch screen
you were hitting it to hard and now you broke it my sister has the saame problem just try to work around it
Oct 18, 2008 | Nintendo DS Lite Console
Ds lite
when i turned on my DS lite it went to the action replay screen but there was no games entered so i tried to add the game it worked sort of when i put my game ID in for pokemon pearl the bottom screen started showing blue and red lines
Sep 03, 2008 | Nintendo DS Lite Console
Ds lite touch screen
Try taking the battery out then putting it back in, if that doesnt work i have no idea.
Feb 13, 2008 | Nintendo DS Lite Console
MMV4205 doesnt heat up
If not a separate fuse, then the hi-voltage inverter or magnatron have likely failed. The first can be $130. The second $45.
Jan 30, 2008 | Maytag MMV4205 Microwave Oven
Cant play any game
Is this the top screen or the bottom screen? The top isn't meant to react to the stylus.
Jan 04, 2008 | Nintendo DS Lite Console
Car Audio & Video Logo
27 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
