Question about Zenith XBS245 System
Zenith xbs245 surround sound system
The power went out to my house and now the system wont turn on after power was restored any help
I have a Zenith XBS245 and I can play CD's but it wont play DVD's. This just started and I cant get the rear speakers to work. I have tried to clean the laser and still no results. What can I do?
Posted on Apr 10, 2011
Xbs344 stuck on prgrogriv scan have sound but no picture
Posted on Dec 21, 2007
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
T.v. wont turn on.
you might find that the power cut has blown the tv does happen - check the fuse first in the plug
Jan 24, 2012 | iLO Televison & Video
Backstory: I have 2 ps3's in the house, both operating under a single account, since the drop of the 'otheroperating' system in march I haven't been able to update the newer of the 2 systems, and am...
Seems like u have a firmware issue or corrupted data..happens alot...simple fix...if this isnt the fix then it wont hurt ur ps3 at all or erase any settings or data...k here goes ...
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM hope this helps..it helped me!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
After power outage, fridge does not work but freezer does
Sounds like a thermostat got damaged when the power surged when utilities were restored. Thermostats are usually behind the temperature controller. Hope I've helped. BB
Jan 20, 2010 | GE Refrigerators
The power went out now it won't turn on.
Look for a fuse or reset on the back of the unit. Check the manaul for their location. You may want to remove the case to check fuses mounted on the board itself. When the power went out something blew. Hopefully it was a fuse. I assume you have tried it at a few outlets already...
Jan 13, 2010 | Crosley iJuke (CR17) Shelf System
No picture for ps3,i went to service menunand did something wrong
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
My iPod touch went all white then after I reset it the screen just went black and wont turn on now. Please help me!
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
  8. Complete an Advanced Restore
  9. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  10. Plug the iPod Touch into your computer.
  11. Power on the iPod Touch.
  12. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  13. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  14. Return to the above section and follow those steps to restore your iPod Touch.
Sep 25, 2009 | Apple iPod touch
When I turn on system it always went to video and playd the movie. Now it wont play movies or do anything. restored but says no data. help
Update your system then restart and clean the disk before playing it. if that dosen't work try a setting reset (hold down power button for 10 seconds ).
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't play my disk-based games
This sounds a similar problem what I had. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Zenith XBS245 System Logo
379 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
xalint1
xalint1
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
