Question about Pool & Spa
Hayward Pool Pump is leaking water. - Pool & Spa
  • John Prohaska
    John Prohaska May 11, 2010
    Post the pump model or picture so I can give you the part number for the seal you need to replace.
    President:
  • 1,378 Answers
Replace the pump seal. For a part number, post a comment with what pump you have. Or if you would like a quote contact us through www.arrowpools.net.
Posted on Oct 02, 2009
SOURCE: Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
Posted on May 29, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
miket756
  • 2702 Answers
SOURCE: Hayward Self-Priming Pump with AO Smith 1 HP 56J
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Posted on Nov 20, 2009
MOTORWIZJ
  • 1340 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Hayward power flo leaks
If it is just dripping a little and it is outside don't even bother until to freezes up. The pool will evaporate much more water than is leaking through the pump.
Jun 08, 2014 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Leak at the pump bump handle
give your model number to pool supply they will set you up
Jul 20, 2013 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Water leaking out the top
Here is a copy of the users manual for these pool filters. It has detailed illustrations about how the filter should be put together.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 21, 2010 | Hayward EC-40 DE Pool Filter with pump
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward pump has a steady water leak between pump and motor
Replace the machanical seal in the pump. It seals the shaft opening through the pump and is about a $5 - $10 part.
Aug 17, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
My Hayward 2 hp pump basket water level drops to about half after the pump turns off. Is there an air leak? No water shoots out when pump is running. Will this damage my pump?
Yes, there is an air leak somewhere.
Only if you are using a timer and the pump fails to prime when the timer turns it on and it runs a long time in that condition. If someone turns it on, be sure it primes and you are fine.
Jul 04, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward pump wont prime. air bubbles coming back into pol with water and de
You have a leak, if DE is getting back in pool your filter is either dirty and needs to be taken apart and throughly cleaned, or you have a ripe in one of the DE cells. The pump not priming is a leak somewhere before where water enters pump. Could be a bad o-ring in a valve. Hard to tell what is is without troubleshooting, piece by piece. I would start with cleaning Filter first.
Jun 17, 2009 | Hayward EC-40 DE Pool Filter with pump
Pool & Spa Logo
538 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
