Question about Targus ACB10US (5024442945809) Bluetooth Wireless Adapter
I INSTALLED A LAPTOP USB BLUETOOTH PROGRAM. WHILE IT WAS TRYING TO RECOGNIZE MY PALM 755P PHONE IT ASKED FOR MY PAIRING CODE #. WHERE DO I FIND THIS # ? THANKS
  • 657 Answers
When it asks you to Enter code, You have to key in any number on your PALM 755P AND the same number on you computer immediately.
Posted on Oct 01, 2009
Testimonial: "THANK YOU, I AM NEW TO ALL THIS AND YOU CAN'T IMAGINE HOW MUCH YOU HAVE HELPED ME !!!!"
    President:
  • 1,462 Answers
Its the code that you should decide, Just type 1234 in your laptop, once you give that code, you would be asked to enter the same code in the mobile..After entering the same code in both the device the device woud be authenticated.
Its just for authentication
Please Rate this solution
RNJ VINODKUMAR
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
When i pair my samsung GT C5130 with my laptop then it ask for pass code to complete pairing process but i don't have pass code .plz assist me
How to Connect a Phone Using Bluetooth With a Laptop
By using Bluetooth technology, you can send files from your phone to your PC without the use of wires, SD cards or memory sticks. Many newer laptops have Bluetooth connectivity, but some models do not. You can make these laptops Bluetooth-enabled with the use of an external Bluetooth device called a Bluetooth dongle. This is a USB stick used to enable Bluetooth on your laptop, as long as it's plugged in.
Instructions
Pairing the Devices
Switch your laptop and cell phone on.
Go to your phone's main menu and enable Bluetooth. Depending on the model of your cell phone, your Bluetooth options may be listed under connections, settings, tools or extras.
Insert the Bluetooth Dongle into the USB port on your laptop. A dialogue bubble will pop up once your computer recognizes the device. Do not close this dialogue bubble until the device has been fully installed. Once it has, you will see the words "Installation Complete."
Go to the Start menu, then select "Control Panel." From here, open up "Network in Internet."
Choose "Set up a Bluetooth-enabled device," then click "Add." After this, select "My device is set up and ready to be found."
Find the name of your phone and click "Next." At this time, you will be asked to give a passkey. The passkey will have been supplied by the manufacturer of your Bluetooth dongle. Enter this same passkey on your cell phone. (You can use the Default code which 0000)
File Sharing
Right-click the file on your computer that you want to send to your phone.
Select "Send To" and then select "Bluetooth Device." A box will pop up asking you to select the name of the device from the list provided. From here, you will select the name of your cell phone.
Click "Next" or "Continue." The file will begin to transfer.
Accept the file transfer on your cell phone.
Hope it helped.
Thanks for using fixya...
Jan 26, 2011 | Cell Phones
Samsung sgh-t139, Bluetooth won't recognize my laptop
Open bluetooth software, open add device, make sure phone is set to visible, then search devices, pairing code should be 0000
Jun 02, 2010 | Samsung Cell Phones
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Loading Palm Treo 755p Software onto laptop with Windows Vista
Make sure it is a 32bit operating system on you laptop...if your operating system on your laptop is a 64bit it will not work. Check the Palm support website to see if they have a current download
Jan 06, 2009 | Palm Treo 755p Smartphone
Connect Nokia 6126 phone to computer with bluetooth
Just enter same number as pairing code for your phone and computer.
I usually enter 123 for both of them!
Jan 03, 2009 | LG HBM 730 Bluetooth Headset Wireless...
I have the Jabra VBT185Z and I am trying to connect it to my Palm Treao' 755P. I have been unsuccessful. It does not recognize the bluetooth headset. When I first charged the earpiece and turned it on;...
I had same problem with same two items. Here is what I did to fix.
Step 1. Delete partnership on phone.
Step 2. Reboot phone
Step 3. Make sure Bluetooth fully charge, and then hold down button so it goes into pairing mode.
Step 4. Enter default 0000 password.
P.S. I had to do it in that order to work, if you don't reboot phone AFTER deleting current partnership, it won't work.
Apr 11, 2008 | Computers & Internet
Tranferring ringtones from SDcard to palm treo 755p
You can use a FREE program for the palm OS called minitones, you can yahoo or google it, which will allow you to convert mp3s you have on your SD card or on the phone to a ringtone that you can assign to a contact. minitones.prc
Mar 23, 2008 | Palm Treo 755p Smartphone
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Computers & Internet Logo
90 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
