Question about Nokia 5500 Sport Cellular Phone
Adobe Reader Hello, My Adobe Reader application suddenly stopped working. When I want to open a .pdf file, I get error message "Application closed: Adobe Reader" It was working fine till now and I didn`t change any settings. I re-installed Adobe Reader, but it didn`t solve the problem. Thank you for any advice.
  • Anonymous Mar 22, 2014
    I have a problem with activation code.The application code is:0093025 and the registration code is:e9ce17can you help me?
    President:
  • 1,944 Answers
A master reset should solve the problem.
Posted on Dec 20, 2007
Adobe files not going to the application
Right click on your file, and then select Get Info (or click on the file once, then go to File -> Get Info, or select the file and press Command-I on your keyboard). This will open the Get Info window.
In the Get Info window, the Open With pane displays a pull-down menu with the application that is currently set to open the file. Click on that pull-down menu, and a pop-up list will display all the applications on your Mac that are able to open the file.
Move your mouse down the list and click on the application you want to open your file.
Now that you've changed the default program for this file, the button for Change All is active. This button will set your Mac to use the selected application to open files of this type. Click on that button.
On the dialog window that pops up asking if you are sure, click Continue.
Done. You can close the Get Info window. If you want to change the default application again or change it back to the previous application, just go through these steps again.
Feb 11, 2015 | Apple MacBook Pro Laptop Computer with...
Adobe reader could not open iexplore.exe because its either not a supported file type or file has been damaged. please help
I am not sure what you are doing trying to open an executable file iexplore.exe using Adobe reader. Adobe reader is is an application to be used for PDF files (*.pdf).
Regards.
May 04, 2011 | Computers & Internet
Cannot open pdf file, says its damaged and cannot be recovered, do I need to reinstall adobe reader?
You will need to redownload the pdf file or get the pdf file from the original owner.
The problem is with the file not adobe reader
Dec 18, 2010 | Adobe Computers & Internet
Tried to download a pdf file and 'Runtime Error' flashed up. This application has requested the runtime to terminate it in an unusual way. Please contact the application's support team for more...
Try unstalling and re-installing Adobe reader. Hope it would fix the problem with acrobat.
Else, you may download latest version of acrobat reader and install it. the problem could be with the file. it has nothing to do with the operating system.
Hope it helps. let me know if any clarification is needed
Nov 04, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
My Adobe reader has stopped working - this happened when I tried to download a pdf file. it flashed up 'Runtime Error' this application has requested the runtime to terminate in an unusal way. Please...
Nov 04, 2010 | Adobe Computers & Internet
Cant open pdf
Make sure only adobe 9 is the only version of adobe reader you have installed on that computer. Then go to where your PDF file is and right click on it with the mouse and go into properties.
In the general tab where it says type of file it will show you what program is opening up the PDF file. Click on the change button and where it says recommended programs see if Adobe reader is there, if its not then down below where it says other programs click on the down arrow and see if adobe reader shows up there. If it shows up in either section then choose it, then click on apply, and then click on okay.
Now if for some reason adobe reader doesn't show up in either section, then you'll need to browse for it. It normally installs itself in the program files folder, then double-click on it and go into the adobe folder, Adobe 9.0 and then the reader folder. The name of the reader program looks something like acrord32 and it will say application to the right of it. At that point choose it and apply the changes so it opens up with Adobe reader.
This should cover everything, if your still having problems, let me know and I'll help you out further.
May 22, 2010 | Dell Dimension 4600 PC Desktop
I cannot download or open any msi file type.
It just, no application can open that file so windows is suggesting to search for application to open/run that kind of files. Say example you have pdf file and you don't have adobe reader or application that can open pdf format it will flag that kind of message for you to be able to view/run it.
Hope it helps.
Apr 24, 2009 | Dell Inspiron 1720 Notebook
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
PDF Converter Professional error
Your converter preferences may have to be changed to allow this document to be opened.
Apr 03, 2007 | ScanSoft PDF Converter Professional...
Nokia 5500 Sport Cellular Phone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
