Question about Canon imageCLASS D320 Digital Copier
Canon ir 2020 system err e354 plese tel me waht ido
2 Suggested Answers
  • 118 Answers
SOURCE: canon ir2020-seystm err e354 please tel me what
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Posted on Oct 03, 2009
Default password for canon ir 2020?
  1. Enter the IP Address of the printer into a web browser.
  2. Enter the System ID. The default ID is 7654321.
  3. Enter the password. The default password is 7654321.
Jul 23, 2014 | Canon iR 2020i Laser Printer
Download standby error for Canon iR 2020
flashing the machine to the latest system software.download sst and firmware.
http://www.smoothprinterservice.com
Jan 22, 2013 | Canon iR 2020i Laser Printer
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Code erreur system E246 E354 canon IR1600 problem:
CANON IR 1600 ERR CODE 354 IT CAME AFTER REPLACING
MAIN BOARD HOW CAN I CORRECT THIS PROBLEM
Dec 27, 2010 | Office Equipment & Supplies
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2022 Printer
Canon iR2016 zerox machin shows system error.E 001. How to rectify this problem please guide me.
these means that you have fixing trouble, probably low or high temperature.
You can clear it in service mode.If it doesn't help you need to change fixing heater.
press *
press 2
press 8
press *
By arrows navigate to CLEAR
press OK
navigate to ERR or ALL
press OK
Turn off and on
Hope that helps!
Notice that under my tips and tricks you have ir 2016/2020 error codes and how to clear certain codes.
Sep 01, 2010 | Canon iR 2016i Black and White Copier
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Jun 16, 2009 | Canon iR 2022 Printer
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Error E354 in copier ir2016
Mar 26, 2008 | Kyocera KM-1505 Copier
Canon imageCLASS D320 Digital Copier Logo
46 people viewed this question
old marine
old marine
