Question about Canon MultiPASS MP730 All-In-One InkJet Printer
My printer does not work when you place it into the standard or draft mode
    Guru:
  • 1,049 Answers
You ink is most likely getting low, or the contacts on the cartridge have dried out. See if replacing the ink resolves the problem.
Posted on Oct 01, 2009
Good day I am seeking for an assistance I need to change the status of an Epson lx350 printer on standard mode to be on HSD/Draft/Roman or Sans mode
The printer settings for the document are set in the document, not the printer. When the document is formatted the print style (font) is set and in the printer properties you should set for draft or standard mode
Sep 01, 2017 | Epson Office Equipment & Supplies
I used to be able to select the draft option when printing, but this seems to have disappeared. I am using an Epson stylus TX100 printer and my document is in Word 7. How do I get draft back?
You can set the option to print in Draft mode while in Word. Follow the steps below and see if it works for you.
1. Go to the MS Office button in Word at the top left of the screen.
2. Then click on Word Options button located to the bottom right of the Office Menu.
3. Select the Advanced Options at the left of the screen.
4. Scroll down and look for the Print Advanced Options
5. Choose "Use Draft Quality"
You can also set your printer's properties to print in Draft mode. If you've tried that and it doesn't work I would suggest updating or reloading your printer's drivers. The print drivers may have become corrupted.
I hope that helps.
Apr 12, 2011 | Office Equipment & Supplies
How many pages can we print from a new #60 black ink cartridge
It can print upto 200 pages, Draft mode printing ( but you can assume it can print upto 120 or 140 pages maximum ( standard printing on A4 Sheet with 1.5" spacing between each line with standard 12 font size )
Jun 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
Printer is printing to fast and ink is faint on paper
I think you are working on draft or economy mode.
do the following:
- click start, select control panel
- select printers and faxes
- right click the printer model you are working on then select properties
- select printing preferences
- depending on the printer model, you can disable draft or economy mode by selecting standard mode or similar to this.
May 31, 2010 | Office Equipment & Supplies
Can not find a way to print in draft mode so toner
Laser printer can sometimes be set via the front panel on the printer for draft mode. Also, you might be able to set Draft Mode from the printer properties menu in the print driver.
The actual easiest way is change your font to something like Courier, 10P, which is a fixed spaced font.
When the document is finished, then you can do a "Ctrl A" and change the font to a more fancy font.
Don
Feb 18, 2010 | HP LaserJet 3600n Printer
How do you set this printer into draft mode? (HP officejet J4580)
Go to Start->Control Panel->Printers and faxes. Then right click on your printer and choose printing preferences. There you will find a setting for quality and set it to draft (or fast draft).
Regards,
nicolasiac
Feb 12, 2010 | HP OfficeJet J4580 All-In-One Laser...
Lost instructions. What cartridges does printer
Here is the manual for your printer with instructions:
http://www.lexmark.com/publications/eng/7100/index.html
Here is the full spec info on your printer.
Print Resolution:
4800x1200 dpi best mode - Photo paper
2400x1200 dpi best mode - All other media
Print Speed:
mono draft mode 22 ppm
color draft mode 15 ppm
Copy Speed:
color draft mode 14 ppm
Fax Speed:
33.6 Kbps
Cartridge Compatibility:
  • Black: Moderate Yield – 32
  • Black: Standard Yield – 34
  • Color: Moderate Yield – 33
  • Color: Standard Yield – 35
  • Photo: Standard Yield – 31
Connectivity:
USB only
Media Handling:
Paper: Up to 150 sheets (20 lb or 75 g/m2 bond)
  • Envelopes: 15 envelopes
  • Labels: 35 sheets
  • Transparencies: 75 transparencies
  • Hagaki: 45 cards
  • Card stock: 35 sheets
Size & Weight:
490.8mm x 422.7mm x 305.4mm (W x D x H)
9.34kg
Scan Resolution:
  • Optical: 1200ppi
  • Interpolated: 19,200 x 19,200
Jan 08, 2010 | Lexmark X7170 All-In-One InkJet Printer
How do I get draft mode (to save ink) when printing on my Pixma iP4200?
goto the printer & faxses
select the printer
from their select the properties
or printing prefrence for printing mode
change the setting to draft mode
ok bye..............
Nov 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Want to print draft mode in dot matrix printer in XP
Not all dot matrix printers will print in draft mode. When operating from DOS it was usually necessary to send an Esc(ape) code such as ESC @ in ASCII code. I don't think it can be done from Windows; in fact some windows programs will not even talk to a dot matrix printer. Some printers have one or two banks of DIP switches, but before changing them you need to read the manual to see what they do. There could be one which allows Draft MOde.
Sep 24, 2009 | Epson LQ-1050 Matrix Printer
Draft mode?
start->control panel->printers and faxes->right click on lexmark E232->properties->advanced->printing defaults->print quality->draft->OK->OK.
Jan 12, 2008 | Lexmark E232 Laser Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
