Question about Curtis-Mathis CM32010 TV
Headphone jack is broken and is causing problem with sound. need part to replace it.
Well I fixed the problem. If you would like to know how, it will only be a fee of $34.95 one time answer..
Digger
Posted on Oct 02, 2009
Headphone jack driver
There is no driver for the analog output. Make sure you have selected the computer internal speakers and the headphone jack will take that output. A more likely cause for your issue is the contacts inside the jack are sprung and are not making contact. If that is the case then the jack needs to be replaced.
Mar 10, 2014 | Acer Computers & Internet
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
Remove broken headphone jack on an Optiplex 745
Since the Headphone jack is soldered onto the motherboard in most cases you could remove it by unsodering it from the MB. However, replacing it might cause another issue. You can always install a sound card that would allow you to have additional headphone jacks.
Jan 17, 2013 | Dell OPTIPLEX 745 PC Desktop
Sound won't work on my Disney dvd/tv combo
Either the speaker is bad or broken wire OR more likely the headphone jack is the issue---when jack comes out it lets a leaf in the socket engage the speaker back----when used a lot the jack causes no sound.
Nov 02, 2012 | Disney DT1350-C 13" TV
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
Dell inspiron 1525 not getting any sound out of headphone jack...I have 2 headphone jacks on the front of my computer. The right one has always worked when I plug headphones or sound cord in. Today, I...
The jack might need replacement since it may be broken on the inside. Also check with your headphones on anther known working device to make sure that the issue is not with the headset.
Sep 03, 2017 | Dell Inspiron 1525 Laptop Computer PC...
You hear one side if I move the cable to the sides and sometimes sounds the other hand I think can be a cable cut
It's a broken wire, obviously. it's probably broken near the jack or the headphone. ur going to have to replace the cable
Mar 08, 2011 | Skull Candy G.I. Consumer Headphones
No sound
See if it works with the headphone jack instead of speakers.
If the sound is intermittant on the headphone jack too then the headphone jack is broken causing the speakers not to work. You could probably find a place to solder the jack.
If it works fine on headphones then either the speakers are bad or the amplifier on the mainboard has failed.
Dec 24, 2007 | Samsung X05 Notebook
Curtis-Mathis CM32010 TV Logo
51 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
