Can the maintenance kit message on the Kyrocera FS-9530 be reset?
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
  • 58 Answers
SOURCE: Kyocera FS-9100DN
Go to the menu on the printer and then scroll down to other in the menu then to service then down to maintenance and press enter. when you install the maintenace kit you have to activate developer in the service menu, then turn off the printer and then back on to run the developer unit up.
Print menumap from the printer and follow through to the service area on the display.
Any question ask me.
Posted on May 11, 2008
  • 58 Answers
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Posted on Jun 27, 2008
Solvedude
  • 7 Answers
SOURCE: NEED SEEVICE MODE PROCEEDURE FOR KYOCERA FS 9120
asfasfa
Posted on Jun 10, 2009
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
How do I get rid of 'Install MK' message?
Missed something, Part of the maintenance kit is the developer and also the drum unit, you will need to change the 1/8th amp fuse in the developer assembly, and also the chip inside the drum unit.
Farnell stock both, the fuses are p/n: 446-816 and the serial eeprom chip is p/n: 690-650
This isnt the exact chip that kyocera use as they use a 93LC56B, but the ones that i have fitted before are 93C46 -these seem to work just the same.
Hope this helps.
Jun 02, 2015 | Kyocera FS-1135MFP
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
Kyocera maintenance kit reset
You can access the following by hitting the menu key
1. Enter the maintenance mode [>>Maintenance].
2. Press the OK key. [>>Maintenance?] will be displayed.
3. Press the OK key twice. The counter for each component is reset immediately.
Aug 26, 2014 | Kyocera FS-1370DN
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
KYOCERA fs-1920 Has the message instal MK coming up? Dopes this mean order a maintenance kit?
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Sep 08, 2010 | Kyocera Office Equipment & Supplies
Message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Oct 07, 2009 | Kyocera Copystar CS-1620 Black and White...
Kyrocera 4000DN
There is a huge problem with the charge rollers in the drum units, but they can't be bought seperatelly. You should have a 3 year warranty on the drum unit.
Aug 12, 2008 | Kyocera FS-4000DN Laser Printer
New maintenance kit
Cheers
Jun 12, 2008 | Kyocera FS-3900DN Laser Printer
434 people viewed this question
k24674
