Question about Brother Office Equipment & Supplies
My printer says it needs to get to room temp but has been saying this for 24hrs
  • 239 Answers
I am not sure what enviroment you are in.
If you are in a cold building, yes this could be true.
Some machines have what they call a "Q", or a comptometer type of electical component built right in the cirucit board. This is a temperture type of componet that works in a certain range of enviroment tempertures. If the area is too cold, it will open up this computent and the machine will not work.
Garages, storage buildings, wearhouses are examples of these places where extreem cold conditions can occur.
If this is not the case in some machines, other causes may need to be explored.
A failed main board, software corruption-software may need to be reloaded by a technition and machine values be added correctly.
Posted on Oct 16, 2009
Tip
Too cool or over cool in room
Indoor sensor to sense the room temp and must cut off the compressor by working. If sensor defective, compressor will continuously running resulting to over cool in room. And also 23 C degree setting temp is best cooling for office and bed rooms. If for peculiar instrument which should be kept under low temp, can be set as mentioned temp (say 18 C or 16 C )<br />
on Jan 10, 2011 | Heating & Cooling
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
Oct 26, 2010 | Whirlpool Freezers
18V Litiom Batteries (Skil)
I would return it and tell them that the battery wont work.
Mar 02, 2010 | Skil 18V Lithium Ion Drill/Driver Model #...
The vegetables in the crisper drawers freeze. What can we do to avoid this?
First try one number at a time, lower the temp control and wait 24hrs. every time you make a temp control adjustment you need to wait 24hrs for it to take effect.
Jan 11, 2010 | Refrigerators
New netbook keeps shutting off. its plugged in and charging.
the other trick wrap battery in a cloth then put in paper bag then a plastic bag put in freezer for 24 hours this will wipe the charge memory in battery.then leave at room temp for about 2 hours and recharge .try run laptop without batt,if it runs with shutting of the batt is dead.
dt
Dec 06, 2009 | Acer Aspire One PC Notebook
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
18 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
