My Rheem Pronto model#RTG-74PNV-1 has powered off for some reason unknown, I turned the unit back on and it supplied hot water for approx. 10 minutes before it started flashing a code [C7]on the remote control UMC-117. Any idea what this code means. I installed this unit myself about 3-years now with no other problems. Help?
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support.
problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative...
(More)
problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
Our Rinnai tankless water heater doesn't put out hot water like it used to. Our temperature is set...
(More)
Our Rinnai tankless water heater doesn't put out hot water like it used to. Our temperature is set at 120, yet outlet water temp is only 108. I recently performed a scale flush using white vinegar. We are seeing any error messages. Thanks for your help.
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before...
(More)
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before the unit will start and run ... very Frustrating... especially in morning. This unit was bought and instlled in Novermner of 2008...
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves...
(More)
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves are fully open. The water heater runs for a few seconds then kicks off and the error code comes up
