Question about Dell 1720dn Laser Printer
How do i get the paper jam light off after i changed the drum?
    Guru:
  • 1,049 Answers
Go back and check the drum and make sure that you did not bump something else out of alignment while installing it; you should not get a paper change light from changing the drum.
Posted on Oct 01, 2009
4 Suggested Answers
vinodgill07
  • 30 Answers
SOURCE: All the lights started flashing after fixed a paper jam
you have take out zamed paper from the printer from the back side of the printer by ejecting the try from back side if it present. or pull out your tonner and then pull out the zame paper.
Posted on Aug 22, 2009
tagmonkey2k
  • 117 Answers
SOURCE: My brother printer HL-2035 keeps
I think you need to reset the consumables counter to clear the drum warning light as the printer can't automatically recognise new parts. If you've bought a genuine Brother drum unit there will be detailed instructions inside the box as to how you reset it which usually involves holding down the only button whilst switching the machine on. As for the paper jams, it could be something as simple as loading less paper and fanning it to get some air between the sheets before sliding it into the tray or it could be that you need to buy a new paper feed kit which is fairly cheap and easy to install.
Posted on Oct 07, 2010
  • 76 Answers
SOURCE: ON OUR DELL 1710 PRINTER,
amma akkuma kaleessaa
Posted on Jun 23, 2011
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
My brother printer HL-2035 keeps jamming the paper. I have changed the drum and toner and the drum light is still on when it prints. Can you help please?
Oct 07, 2010 | Brother HL-2030 Laser Printer
Paper jam light will not go off and there is not paper jam in the unit.
Over time paper dust and toner residue can build up around the drum and paper feeder rollers. Open your printer and remove the toner cartridge and Drum unit. Use a soft brush to clean any residue. Replace toner cartridge and drum unit.
A tiny bit of paper can cause the paper jam light to stay lit.
Jan 16, 2010 | Office Equipment & Supplies
Aug 22, 2009 | Digital Products Brother HL-2040 Laser...
My MFC-7420 jams paper after each copy what is the problem.
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
May 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Crinkled paper and jamming
Where is the paper jam ???? If you have a paper jam in the back of your printer it maybe the fuser unit.....Make sure thaht you don't have a little peace of paper somewhere in the paper path...
For your drum, did you reset the drum counter ????Normally the instruction for resseting the counter is in the drum box...
Mar 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
Dell 1720dn Laser Printer Logo
133 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
