Question about Homelite Garden
Homelite 42cc, 18" bar chain saw - Engine will not restart after saw has been used for a while. Wait overnight and it starts fine.
    Guru:
  • 597 Answers
After it has been used for a while and it won't restart, try loosing the cap to the gas tank and see if there is pressure escaping. The homelites are notorious for the vent screen in the gas tank cap getting dirty and pressuring up which forces more fuel into the carburetor and floods the motor. This is also aided by spilled mixed gas which has oil in it running down onto the cylinder heads and then the sawdust sticks to it over time and building up where it makes it difficult for the cylinder head to get rid of all the heat it makes from running. This in turn makes the gas tank hotter and makes it build up pressure in the tank. If the vent cap cant get rid of it as fast as it is created the increased pressure forces too much gasoline into the carburetor and it floods it out.
Posted on Oct 01, 2009
How to remove sprocket from chainsaw ut10588
Also if yours has a chain brake make it is in the release position. A few of these saws had them but not all.
Nov 20, 2014 | Homelite UT10580 18" Gas 42cc Chain Saw
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Chain saw ran for a few minutes became hot with little smoke and now will not start again.
It could get hot and not start if the saw was quite dirty because it relies on air for cooling and if the fins can't get enough air around them it would heat up and not start. Another thing is if some one did not use the correct gas oil mixture it would get hot and score the cylinder lowering the compression causing it to not start.
Mar 17, 2011 | Homelite ZR10580 FactoryReconditioned 42cc...
Hi have a homelite ZR10580 chainsaw thats seems to be sending out too much chain oil but I don't see any adjustment for this?
1st. are you using the saw in a hot environment? warm chain oil will run easier than cold.
2nd. are all parts clean? remove the guard, chain and bar, clean the oil holes and contct points to reduce airlocks and allow oil to flow as it should.
3. Which oil are you using? I found Texaco Clingtex oil behaves well in all enviroments.
4. Have the oil pump checked... the seals on these saws arn't great and after a few years they can peish and allow too much oil through.
hope this helps.
Jan 13, 2011 | Homelite ZR10580 FactoryReconditioned 42cc...
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain tension adjustor will not tighten. Is it striped?
It might be, but the chain has probably stretched past the limit. If you buy a new chain and match it up to this one, you won't believe the difference. If that is not the problem, take the chain off, take the bar off, clean out the adj screw, make sure it moves, set it back as far as you can, put the bar and chain back on, make sure you are in the drive sprocket, put the nuts on, adj the bar, tighten up the nuts, you should be set. My adj screw gave out long ago, I just pull the bar tight and go. Hope this helps.
Aug 16, 2010 | Homelite ZR10580 FactoryReconditioned 42cc...
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
With the chain off the device, I start the engine
Is the Chain brake engaged? It's the plastic "guard " in front of your left hand.
Apr 21, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
295 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
