STOPPED WITH ERROR CODE E30 - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 75,822 Answers
Can u give me the make and model of washer please, error codes are diff for every manufacturer and in most cases even the model has diff codes.
Posted on Oct 01, 2009
  • dizzyblon511 Oct 29, 2010
    Affinity frigidiare
Canon irc2100
Sir, there doesn't seem to be an error code accounted for that reads E30.
Canon IRC 2100 Service Repair Manual
That is the link to the service repair manual which also has the error codes so you can diagnose what is going on although there doesn't seem to be an E30 code accounted for.
This is a more extended list of all of the error codes and once again there seems to be no E30. There are 9 pages of error codes if you'd like to look.
Error Codes Canon iRC2100 page 1
Perhaps a mistype?
Aug 30, 2014 | Canon iR 2016i Black and White Copier
Code e30 error
Hi John, thank you for your inquiry!
If you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, and based on the symptoms you are describing it could potentially mean a number of things: a pressure sensor issue, defective wiring, faulty pump, and valve assembly problem and/or control board issue. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Thank you for allowing me to assist you in a small way.
Sep 15, 2013 | Frigidaire ATF6000ES Front Load Washer
E30 water will not stop coming into drum
Good Afternoon Donna, I am happy to assist you. If you are receiving an E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Aug 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have washing machine hotpoint model wm71n showing error code E30 and washing machine rund for one minute then stops, please tell me what i should do.
Error code E30 generally indicates a problem with the motor.
Check brushes and associated wiring and connections.
Oct 30, 2010 | Washing Machines
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Aeg 74640 error code e30
What does the E40 error code mean?
Jul 09, 2008 | AEG Lavamat 74640 Front Load Washer
Washing Machines Logo
532 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
