Question about Drills
I have a aeg drill tc 25e 1 and i don't know how to replace the screwdriver tip
    President:
  • 1,714 Answers
Turn the 'chuck' at the end of the drill with your hand to loosen the bit, then remove.
Posted on Oct 01, 2009
I have a Bosch 14.4 driver and with full charge I han hold the chuck an prevent from spinning when on drill speed. Can I fix this?
Battery powered drills generally are much weaker thah house current drills. With that in mind, realize that they aredrills and not intended to be power screwdrivers! The less the supply voltage, the less the torque (turning power). They are suppurb at doing small jobs where torque is not an issue, like using drill bits through wood, etc!
Dec 31, 2012 | Drills
Who repairs AEG hammer drills
No one anymore. AEG was bought out by Atlas Copco which also owned Milwaukee, They were then bought out by T TI who owns Ryobi. Milwaukee quit furnishing AEG parts many years ago so finding parts will not be easy. Your best bet would be to replace it and move forward.
May 01, 2012 | Drills
Makita bhp453 chuck screw wont loosen
The chuck screw on drills is put in with lok-tite and is reverse threaded. You need to get the screwdriver on it firmly and turn it clockwise, as you are, with strong, constant pressure until it breaks free. Don't let the screwdriver slide out of the screw slot, if you round off the screw head you'll have to cut the chuck off. If it still won't break free, try putting the drill in a vice or use a screwdriver with a hex nut molded into the driver shaft so you can use a wrench for some more torque.
Mar 11, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Don't know how to attach a screw on to my corded Skil 3/s drill. Is there a special bit for this purpose?
Hi auntygamma,
Welcome to fixya!
Yes, you need to use a bit with all drills. They come in different sizes and shapes. If you don't have any bits to put into your drill, an all purpose kit would be nice to have. You can find them at your local hardware store or online.
Check out this webpage: http://www.toolup.com/dewalt_dw2163_37-piece-screwdriving-set-with-tough-case.aspx
Copy and paste this entire web address into your browser and a page with one of the kits on it will open up for you. You don't have to buy a kit with lots of bits, you can pick up just one or two bits that you would use the most at the hardware store. The most used bits would be the #1 and #2 Phillips bits and a couple of different sizes of flat bladed bits. A few drill bits might come in handy too.
The drill that you have has a keyless chuck. This means you don't need any special tools to put in a bit or change one. If you look at the chuck, you'll see that the ridged part has two sections. If you hold the back section with your left hand, you can turn the front section to either open the chuck or close it to put bits in.
I don't know if this was clear or not, but if you have any problems or more questions about this, please be sure to reply back. I'll be glad to help you.
Thanks,
Handie Andie
Aug 14, 2011 | Craftsman 3/8" Corded Drill
My problem is my 18volt cordless drill driver cant work in Jamaica where ive been trying to use it cause its 50hertz and not 60 here Rigid customer support said i could try and locate 50cycle charger...
I dont know that the small difference in hertz would make a huge difference. What is the voltage 120 or 240? that would be my concern. And the company AEG is actually a german company that manufactures tools. They also make tools for many other tool companies e.g. Milwaukee Tool. I just searched and by entering the words aeg.com I came up with their website, you can browse the site or send them an email for advice. Let me know if you need more assistance and if I have helped you would you please vote accordingly.
May 24, 2011 | Ridgid 12 Volt Cordless 3/8 In. Drill
I need to remove the chuck on my dewalt keyless chuck and don''t know how
go to the tip section under my handle and there are detailed instructions that will work with your drill. If you have a problem finding them let me know.
Mar 22, 2011 | Dewalt 3/8" Electric Drill D21009
How i remove a dewalt drill chuck Model dc988
put the drill in speed setting 1 before you continue~!
Step 1. This step loosens the screw inside the chuck. Open the chuck all the way — if you see a screw inside, it’ll need to come out before you can remove the chuck. If there’s no screw inside, you can skip steps one and two.
Step 2. If there’s a screw inside the chuck, typically the threading will be left-handed, so turn it clockwise to remove it. Be careful, and use the right size screwdriver — you don’t want to strip the screw.
step-2.gif Step 3. Insert the largest hex key that you have into the chuck, short-side-in, and tighten the chuck. Tap the hex key sharply in a counterclockwise direction to loosen the chuck. Now you can remove it by hand.
step-3.gif This won’t work for every consumer drill ever made, but pretty close. Most drills will match one of two common chuck-threading standards: 3/8′-24 threaded mount for 3/8′-capacity drill chucks, and 1/2′-20 threaded mount for 1/2′-capacity drill chucks — but on some drills just the opposite may occur. To be safe, always check the thread count before you buy a replacement drill chuck.
Oct 07, 2009 | Dewalt DC988VA XRP 3 - speed 1/2" 18v...
How do you replace a drivers door window motor? I already drilled out the rivets but don't know how to disconnect it.
You will need little flat tip screwdriver and pry up off the wiring connector if it is this type.
If it is straight wired, then cut wires about 1/2 foot up from motor so you can fix that later after new one is installed. Will make it easier this way.
Aug 29, 2009 | Lincoln Town Car Cars & Trucks
Drills Logo
185 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
