Question about Lite On LVW-5115GHC+ DVD Recorder
Operating manual and/or startup disk
I have had a LVW-5115GHC+ for about a year and have used it as a player only up to now. I'd like to record now and can not find my support "manuel/disk for operating instructions. Where can I get this information(ie disk or manual)??
  • Belvido Feb 03, 2008
    I need the Manual for the Liteon LVW-5115ghc so I can sort out the SCART connections to another DVD player, TV & Set Top Freeview box
Http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=154
Posted on Jan 06, 2008
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
I need a user manual for a liteon lvw 5001 email address richard_beck@btinternet.com
Go to Liteonit internet site.You can download a free manual and put on a CD disc.
Mar 20, 2009 | Lite On LVW-5005 DVD Recorder
We have lost our instruction manual for our dvd recorder
You can get the manual here, but you have to sign up to their site, which is Free.
http://www.retrevo.com/support/LiteOn-LVW-5115GHC%2B-DVD-Players-manual/id/2453ci363/t/2/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 21, 2009 | Lite On LVW-5115GHC+ DVD Recorder
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
Doesn't recognize disks anymore
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Dec 29, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5115GHC
Try cleaning it again. Did you clean all the sensors? In order, you first remove the exterior cover with the 2 large side screws on the side (one is under a sticky label) and then on the back, remove the 4 screws around the perimeter of the cover. Pull off the cover and then remove the 2 screws on the silver colored plate over the CD/DVD drive. Then spring in the 2 tabs toward the rear that lock down the rear of the drive cover, and lift the silver cover off the drive. Now there will be an obvious lens and a couple of more light output devices that don't look like lenses. You should see them off to the side after you look it over well. Cleaned with Isopropal and dry with a dry q-tip. After I did this, I had the same problem still. I then took the unit apart again out to the garage and used a throttled back air stream from my air compressor to clean all around the the sensor head. I re-assembled it, put in a DVD and it played OK.
Sep 25, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5115GHC+ DVD Recorder Logo
73 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
