Question about GE Profile PDS22SBSRSS
I have a GE PDS22SBSARSS, just under 4 years old. Several times a day it clicks for a few minutes, during which time there are no temperature readings on the display. When it stops, the temperatures are much colder than the settings - just now the freezer was showing -15(set at 0) and the refrigerator at 11 (set at 37). What's up?
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
  • 116 Answers
SOURCE: Model # PDS22SFSBKSS Bottom Freezer. Its making a
Hi you need to replace the main motherboard, depending on the age you should call GE if they service your area they will discount the cost of the repair if it qualifies and its cheaper than doing it yourself, if it doesnt qualify then the board usually is around $175.00 just to buy not including to install if you have it installed, this needs to be done quickly prolonged use with bad motherboard on this model will damage sealed system, ruining the entire refrigerator. If you need further assistance let me know.
Sean
Posted on Mar 27, 2011
Running hotter than normal. 93 eagle vision TSI 3.5 L
Check the thermostat for debris since you could have knocked something loose during the water pump swap. I would probably buy a new thermostat because they are cheap/easy to swap and you could always return it. A timing belt is a pretty extensive undertaking especially in a front wheel drive in which the engine may need to be un-mounted on that side, and likely many other things disconnected and reconnected throughout the process. Did you swap the timing belt, or take it to a shop. It may still be covered under some type if limited warranty if you could prove this to be the cause.
Dec 03, 2013 | 1993 Eagle Vision
My GE fridge model PFS22SBSASS clicks for hours at a time then goes off for a day or so. We suspect thermostat. It is 4 years old. Seems to be working normally but fear breakdown
Greetings,
you say you hear a clicking sound? if this happens every five minutes or so and the compressor won't start...its most likely the ptc assembly(starts compressor) its even possible compressor at fault, but if it works ok for awhile most likely the PTC needs replacing....Bruce Denton
Nov 28, 2010 | GE Refrigerators
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
The refrigerator has almost stopped chilling. The dial setting was on 4 for both refrigerator and freezer. Last night there was a buzzing and when opened it was seen that the freezer compartment had a few...
If the starter relay at the compressor is not the problem then the compressor is. I would replace the relay(you should be able to find it by the click when the compressor starts) and if that don't fix it a tech would have to be called.
Aug 14, 2009 | Amana ABB192ZDEW Bottom Freezer...
GE Profile Refrigerator clicking
Sounds like the main control board is bad . Check your warranty to see if board could still be covered .
Aug 08, 2009 | Refrigerators
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
Not working
If the clicking sound is coming from the back of the refrigerator at the compressor, you have a faulty starting device or faulty compressor. The compressor has a 5 year warranty so call to have someone out if you can.
Feb 01, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
Several Related Issues
shado In order to better help you I need the complete model number and the color for your range.
Feb 03, 2007 | GE Spectra JGBP35 Gas Kitchen Range
GE Profile PDS22SBSRSS Logo
174 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
