Question about Juki Sewing Machines
Need a good thread guide for Juki serger MO2416N. The one that comes with the machine is unhelpful, to say the least. Need one that clearly shows which thread goes where, in which direction, etc.
5 Suggested Answers
  • 47 Answers
SOURCE: Need a "How to Guide"
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
  • 1116 Answers
SOURCE: good diagram showing how to thread a 4 thread Juki
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Posted on Mar 02, 2010
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
How to thread my Juki MO-114D
Am unable to locate any videos online.
Perhaps the manual would be helpful. If you are having problems seeing the pictures, you can enlarge them on the computer and perhaps that will help. Perhaps you can take it to a Juki dealer and ask them to show you.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwib6a3im83LAhUit4MKHQUNAUkQFggdMAA&url=https%3A%2F%2Fwww.juki.co.jp%2Fhousehold_en%2Fserger%2Fpdf%2F40166075_MO-114D_104D_EG_20150715.pdf&usg=AFQjCNFBh_wgoWpyuWvUI5eJ4HAm-QwgoA
Juki MO 114D Serger Overlock Machine at Ken Sewing Center
Mar 19, 2016 | Juki Sewing Machines
I need replace thread holder for Juki MO-644D serger
Good luck. I found a replacement part for one of mine on Ebay. Just search for Used Juki Serger for parts. Maybe you'll find a 644D for cheap enough that you can scavenge parts for a few more years.
Oct 25, 2012 | Juki MO-644D Mechanical Sewing Machine
How to thread a juki serger sewing machine. i need a large diagram of how to do it. thank you
do you know what model Juki it is? Is it a serger or a sewing machine? Juki do industrial straight, serger and specialised machines such as coverstitch and blind hemmers as well as domestic sewing machines and sergers so there is a big range of machines.
There are manuals at this site for http://jukihome.com/products/mo644d.html various models of Juki Home sergers, but you will need to hunt through and find your model.
The manual is on the "features" tab for each model so just dig down a bit to locate the pdf file in there.
I hope this is what you were searching for.
Jun 03, 2011 | Juki Sewing Machines
Do you have a quick threading guide for this
Could not find. Here is one for the 634 that may help - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Raise the thread antenna and loopers to their highest position.
Set the tension controls to zero before threading.
Many sergers have the threading diagram inside the front door of the serger.
Apr 01, 2010 | Juki MO-654DE Mechanical Sewing Machine
Don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
Mar 12, 2010 | Juki MO-735 Mechanical Sewing Machine
Good diagram showing how to thread a 4 thread Juki 644d serger we do not have a manual machine is not clear
Threading Tips:
Mar 02, 2010 | Juki MO-644D Mechanical Sewing Machine
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
154 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
