Question about TruTech PLV1615T 15 in. LCD Television
How do i scan for channels? Do not see an option
How do i scan for channels? Do not see an option on the menu. have not used tv since digital conversion
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
How do I get digital channels instead RF channels on my TV DWM32H1G1
Have you hot a digital receiver connected to the TV.....Sky or Cable?
Jan 02, 2015 | Televison & Video
How do i select the channel menu
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Dec 15, 2014 | Televison & Video
Why is the tv not finding channels when channels are scanned?
make sure your tv is set to pick up the signal it could be cable digital or analog channells.there should be an option for this in the menu.
Jun 04, 2012 | Scott LCT37SHA TV
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Feb 12, 2011 | Toshiba Televison & Video
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
TruTech PLV1615T 15 in. LCD Television Logo
67 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
