Kyocera Copystar CS-1620 Black and White Copier
Problem for Kyocera Copystar CS-1620 Black and White Copier
When I print multiple copies from a networked
By mistywiddget on Oct 01, 2009
When I print multiple copies from a networked computer, the Kyocera CS-5050 (KPDL) staples all the copies together with one staple rather than stapling each set. I can't find this model number in the site inventory.
Best Solution
posted on Oct 03, 2009
Very Helpful)
mdroark33
Rank: Guru
Rating: 89%, 34 votes
when you click on file then print look in bottom right corner and you will see a box that says collate uncheck that box and it should staple correctly for you
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" It worked! So simple! Thanks! " - mistywiddget
Popular Solutions for Kyocera Copystar CS-1620 Black
Questions and Unsolved Problems for Kyocera Copystar CS-1620 Black
Do you recommend Kyocera Copystar CS-1620 Black and White Copier?
Answer
Answer
Error message 45-1 is being display on Konica Copier model 3135
Answer
konica 1216
Answer
check to see if the fuser is working yu should be able to tell if you open the side door up at the... (More)
Answer
I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Copystar CS-1620 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
