Question about Refrigerators
Defrost does not work properly, continues to freeze up element in lower freezer compartment, shutting down cooling in upper refrigeration unit. We continue (bout every two weeks) to take wall unit off and using hairdryer to melt the ice build up. How do we fix defrost system?
    President:
  • 1,304 Answers
Is the fan working
nex time you defrost in spect the terminator
it looks like a lil button on the coil should have an orange and brown wire,,,, could be stapped with metal clip... if its poped open thats your issue replace and you should be fine;
im including the part number,,, you can order form sears AP4079076
it a defrost thermostat
Posted on Oct 04, 2009
  • 80 Answers
I noticed ice build up towards the bottom right corner of the back panel (in freezer)....i diconnected power...took the back panel off .....fan had frost on it....coil was iced up.... then on the back of the refrigerator i accessed the control board....plugged the power back on ...i jumped the line to the heater...heater didnt work....then checked resistance through the heater (checked ok)....
it came down to me replacing the defrost thermostat which is in series with the heater....defrost now works fine ...which is every 60hrs for 45 minutes on mine.
Posted on Oct 02, 2009
Whirlpool S20b American style f/f. The fridge is very cold and some foods are freezing.
Suggest lowering the refrigerator set point to a lower number such as 3. There is usually an indication of normal setting on the adjustments. Wait 24 hours and check the refrigerator compartment again. Use a thermometer to record the temperatures. The meat compartment will be normal just below freezing. If no success then read the following.
One reason that this occurs is that the unit is working near continuously to reach the freezer temperature. Another words the unit is not capable or cooling the freezer to the prescribed temperature. The result is the excess cooling eventually reaches the refrigerator section causing the refrigerator to freeze. The unit will if this is the case run nearly continuously. This situation is counter intuitive. Freezer not reaching set point, excessive cooling over cools refrigerator therefore refrigerator freezes.
The cause is either the freezer door/seal is not closing or sealing the freezer compartment or the compressor or defrost cycle is not functioning properly.
Check the freezer door seal using a strip of paper. Check to see if air is flowing from the vents in the freezer. Using a thermometer check the temperature of the freezer. Listen for and record if the compressor is running or not.
The normal freezer temperature is around '0' Fahrenheit. If no or little air is flowing from freezer air vents look for ice on the back wall. If ice is present it is likely the auto defrost cycle is not working. Attempt to defrost by hand which requires several hours with everything removed.
Check that lint and dust has not blocked the coils under the unit and that the lower fan is running. Usually warm air exits from the machine grill in the front. Remove the grill and check for air flow and debris buildup. Vacuum if necessary.
And unfortunately if the compressor runs continuously and no air blockage underneath would indicate that the cooling capacity is reduced requiring a major service or replacement.
Hope this helps?
Oct 17, 2016 | Whirlpool Refrigerators
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Crystal cold lpg fridge the fridge part works fine but the freezer only cools to the same temp as the fride compartment
The freezer should go down to about zero degrees. If your unit is constantly running it is because the internal temp has not activated the thermostat to turn off the compressor. Lower than normal refrigerant levels could account for this. Also to be checked out is the evaporator coil not being frozen over with a block of ice - the latter is caused by an inoperable self defroster - this causes the freezer to not cool properly and raise all internal temps.
If not a self defrosting unit, defrost the unit and restart unit. It will cool properly until the evaporator freezes up again. How fast it freezes up depends on how often the freezer door is opened and how much moist warm air enters the freezer compartment.
Nov 21, 2013 | Refrigerators
Model RT14HDXGW02 Refrigerator compartment wasn't
Yes its possible that the defrost water instead of going down the drain properly, its clogging the airways. pull the covers off and see if the defrost drain is plugged or frozen. clear it if its plugged and make sure panels and gaskets go back on properly
Jun 24, 2011 | Roper RT14DKX Top Freezer Refrigerator
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer fine / fridge warm
check for defrost element not working ice build up will cause it not to cool fridge,check continuity of element with unit unplugged!!!if continuity ok then check defrost timer!!! :)
Jul 07, 2009 | Refrigerators
FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
May 05, 2009 | Refrigerators
Cooling sometimes, freezer leaking water when it stops freezing
It is probably the defrost thermostat located on upper condenser coil to the left of the fan in the freezer compartment. If not, it could be the defrost timer located near the thermostat in the refrigerator under the plastic dome where the light is. If the defost thermostat or defrost timer is not cycling the defroster heater element on and off correctly... an ice dam forms clogging the drain tube which freezes and blocks water (from the the defroster) to draining down and into the evaporator pan located on top of the compressor in the rear of the unit near the floor.
Mar 31, 2009 | KitchenAid Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
