Question about Mercury P4VM800M7 Motherboard
ABIT-KR7A Motherboard Connections from motherboard to two front end USB ports have become disconnected.  Would like to know which wire goes onto which pin.
  • 1 more comment
  • Anonymous Feb 19, 2008
    connect
    how do I connect the wires to the usb 3 & 4
  • Anonymous Mar 21, 2008
    President:
  • 2,351 Answers
Your manual here: http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&model=86
Bios & Drivers Download:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=4&category=5&subcategory=258&model=86&product_name=KR7A-133R
Go to page 7 of your manual. The pin layout is shown here. The manual states that these can be used at the back of the Pc but can also be used at the front of the Pc. For understanding the wires click this link: http://www.directron.com/installusb.html
Scroll down till you see in bold lettering (Understanding the wires). A picture is worth more than typed words. Enjoy!
please vote...
Posted on Feb 02, 2008
Is there a way to put more than 2 Gigabyte of RAM onto an Abit LG-95Z motherboard?
No, the mainboard does not support more than 2 gb of ram.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=LG-95Z
CPU
  • LGA 775 Socket for Intel® Pentium® Dual-Core / Pentium® D / Pentium® 4 / Celeron® D Processors with 800 MHz FSB
  • Supports Intel® Hyper-Threading Technology
  • bullet_31.gif Chipset
  • Intel® 945GZ / Intel® ICH7 Express Chipset
  • bullet_31.gif Memory
  • 2 x 240-pin DIMM sockets support max. memory capacity 2GB
  • Supports Dual Channel DDR2 533 Un-buffered Non-ECC memory
  • bullet_31.gif Graphics
  • Integrated Intel® Graphics Media Accelerator 950 (Intel® GMA 950 )
  • bullet_31.gif LAN
  • On board 10/100M PCI controller
  • bullet_31.gif Audio
  • On board HD 7.1CH Audio CODEC
  • bullet_31.gif Expansion Slots
  • 1 x PCI-E X1 (Wi-Fi Accessories)
  • 2 x PCI
  • bullet_31.gif Internal I/O
  • 1 x Floppy Port supports up to 2.88 MB
  • 1x Ultra DMA 100/66/33 IDE connector
  • 4 x SATA 3Gb/s connector
  • 2 x USB header (support 4 ports)
  • 1 x FP-Audio, 1 x CD-In
  • bullet_31.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 Mouse
  • 1 x Serial port, 1 x Parallel port, 1 x VGA connector
  • 4 x USB 2.0, 1 x RJ-45 LAN connector
  • 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
  • bullet_31.gif Serial ATA
  • 4 x SATA 3Gb/s offer by Intel® ICH7
  • bullet_31.gif Form Factor
  • Micro ATX form factor 244 x 244mm
  • PCB Color: Blue
  • Aug 21, 2011 | Abit LG-95Z Motherboard
    I had to change the motherboard as it failed
    Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
    Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
    USB wiring on KT4AV MS-6712 Ver 10A motherboard
    Open the link provided; http://www.directron.com/installusb.html
    You will need to scroll down until you see, Intel Standard USB header Layout. Also see: Common USB case header connectors.
    Hope this is what you're looking for.
    Cheers'
    Mike
    Feb 07, 2010 | Intel Motherboard
    Dont know where an item should go
    This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
    Mar 23, 2009 | Abit NF7-S V2 Motherboard
    Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
    Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
    Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
    Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
    I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
    Help this helps.
    anon paranoid
    Feb 18, 2009 | Abit KG7-Lite Motherboard
    Wiring off the tower
    The 2 grey wires with the 4 pin connectors would be for the USB ports at the front of the tower. They need to be connected to the motherboard usb pin outs. Usually marked on motherboard as "USB1", "USB2" etc. Generally the red wire should be the "power" and goes to pin1 or 2 on the connector. Pin 1 is normally marked by a thick line on the board at that end of the connector, but it's easier to say Pin1 is the opposite end to the single pin on it's own (which isnt used). You really should check the manual for the board to confirm the connections though.
    Jan 03, 2009 | ASUS P4P800 SE (890552603657) Motherboard
    Abit se6 motherboard
    Hi bdb124,
    Trying to hook up any USB ports is not an easy issue unless one can include pictures. Click on this link provided. Its a walk through & will help you hook up your USB ports.
    Good luck bdb124!
    Mike
    Nov 10, 2008 | Abit SE6 Motherboard
    Upgrading CPU
    Abit KR7A-133R Motherboard
    Socket A (also known as Socket 462) is the CPU socket
    Best I can tell you should be able to get away with it.
    http://www2.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KR7A-133R&fMTYPE=Socket%20A&pPRODINFO=Specifications&fSEARCHTEXT=KR7A-133R
    Dec 18, 2007 | Abit KR7A-133R Motherboard
    Usb shortage
    There's a photo of your motherboard here: http://www.techspot.com/reviews/hardware/abit_vt6x4/ You see the part labeled "USB header for two extra USB channels." That is where you'd connect any additional USB ports. When you say you have two ports on the front of the stack, I assume you mean on the front of your computer case? Front mounted USB are handy, and just about standard on most cases. Just connect the cable from them to that connector and you should be ready to go. If you're not sure which way to connect it, just try one - you won't break anything by connecting it backwards (you'll just have to switch it to get them to work).
    Aug 30, 2007 | Abit VT6X4 Motherboard
    Flash Disk goes bad
    Did you assemble the board yourself into the case? check to make sure your front panel USB connections are installed onto your motherboard in the correct order. Refer to your Motherboard Manual.If they are not, they can fry your usb devices rendering them inoperable on your pc or others. I have seen this before because of improper installation of front pannel USB connections. Good Luck
    Apr 09, 2007 | Intel D915GUX Motherboard
    Mercury P4VM800M7 Motherboard Logo
    146 people viewed this question
    Top Mercury Computers & Internet Experts
    Mark Gough
    Alun Cox
    vsri9
    Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
