Home | Biostar | M7VIG-400 (M7VIG 400-COMBO4) Motherboard | PC wont start up, No sin...
Biostar M7VIG-400  Motherboard
Problem for Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard
PC wont start up, No single led is on.
By osvaldo_cab on Oct 01, 2009
I got 2 PCs, one of them shows and do nothing when I push the power button.
The error first started to freezing the PC and by restarting the issue was solved, but lately the PC wont restart and I got the Restart led and CD Drive led blinking. Now even the leds has gone.
I've put the RAM, HDD, CD Drive and even the power supply on the other PC (the one that stills works) and they look fine, no errors found no wierd sounds.
Is there something I can do to save the PC?
Thx in advance.
Best Solution
posted on Oct 01, 2009
Very Helpful)
preachw996
Rank: Guru
Rating: 86%, 729 votes
If the components test fine in another pc then it is the motherboard that has went bad. You can try to find the same type as a replacement if you want to salvage the CPU, RAM, etc., but it may be more feasible in the long run to buy a barebones kit and just use your optical drive out of your old pc. Problem would be solved and you would have newer technology. Hope this helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Makes sense, If everything goes Ok on a separate PC, one left thing is the MoBo. I'll use the parts as spare and buy a new MoBo. Thx. " - osvaldo_cab
Solution #2
Helpful)
purple_pizza
Rank: Guru
Rating: 86%, 46 votes
Check on the back of the switch, the wires may have fallen off, or the switch fell apart.
Comments:
Oct 01, 2009
- What about taking all the wires, ONLY one at a time, and disconnect, then reconnect? Just to be sure it is not a bad wire connection. It probably is the motherboard, but just a shot, you know.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" I've checked already and the problem stills. Thx. " - osvaldo_cab
Solution #3
posted on Oct 08, 2009
Not Rated)
adelson-1990
Rank: Apprentice
Rating: 0%, 0 votes
It might also be the motherboard. that has a problem, have you ever replaced the cmos battery? You can't mess up your motherboard, if you don't really know what your doing, you have to be every careful, with the motherboard. I recommend that you buy a cmos battery, I can't promise you that is the problem, but it sounds like it. It might also be a transformer that died. THE MOTHERBOARD IS A VERY DELICATE AND AMAZING PIESE OF EQUIPMENT.
Was this helpful?
Yes
No
Popular Solutions for Biostar M7VIG-400 Motherboard
Questions and Unsolved Problems for Biostar M7VIG-400 Motherboard
Do you recommend Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard?
Answer
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Answer
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the... (More)
Answer
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card... (More)
Answer
en donde en Cuentro los controladores del teclado USB de la m7vig jabalí 400
Answer
tengo un disco duro de 40 G y la placa madre me manda un mensaje de error al cargar el sistema... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Biostar M7VIG-400 Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14739
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
