Question about Ovens
Oven clicks continuously after turning on....
When I turn on my oven on my Amana RLN385UWW it will often continue to click for a long time. This does not happen all the time but happens frequently. Can this be fixed? Is this dangerous? The oven does heat fine.
  • robertstory Oct 01, 2009
    I don't understand. Can you help?
fridgetech
  • 473 Answers
SOURCE: gas leak from oven
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Posted on Nov 07, 2007
SOURCE: Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Posted on Jun 17, 2008
docjohn174
  • 943 Answers
SOURCE: F1 error on SS Amana Convection wall oven
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
SOURCE: Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Posted on Nov 02, 2008
  • 583 Answers
SOURCE: Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Posted on Mar 03, 2009
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
The ignition on the gas top continues to click after being turned off
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 08, 2011 | Jenn-Air JJW8530C Expressions Collection...
Oven started making a clicking noise after I started the self-cleaning process. Continued until "F8" flashed next to the clock. When canceled was pressed, the clicking started again. As a...
F8 means a fault on the door locking switch.
Something may be preventing the door lock from operating properly.
The solution is to have the door lock switch and wiring checked over.
Dec 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
The oven shuts off after 12 hours. How do I leave it on longer?
Hello, I found this info on the manual for your oven:
12-hour automatic cancel This safety feature prevents oven from continuing to operate if it has been left on for over 12 hours. If a cooking function continues longer than 12 hours without any options on oven control being touched, this feature turns oven off. Any time an option is touched, 12-hour automatic cancel is reset.
If you want to print up your own owner's manual, here is the Amana link. Just type in your model # and then click on the link to read it or print it up
http://shop.amana.com/product_literature/search_results.jsp?searchTerm=AOGD2750&siteCd=AMA&userType=Consumer
May 19, 2010 | Amana AOGD2750 Stainless Steel Gas Double...
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Amana wall oven
Hi~ According to the manual for this oven, the F2 code signifies - high oven temperature. The only suggestion for any of the codes in the manual is to disconnect the electrical supply. It says" pressing OVEN CANCEL pad or disconnecting electrical supply may eliminate "F code". If failure continues, contact an authorized servicer.
I hope this helps. Linda
Dec 03, 2007 | Amana AOCS3040 Electric Single Oven
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
