Hotpoint aquarius wma 54, drum wont turn or wash.
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Motor brushes perhaps..
Posted on Oct 01, 2009
My hotpoint Aquarius has suddenly started being very noisy on the spin cycle. Why is this .
heavy clothes... like jeans and all on 1 side while light clothes (cotton) on the other... causes jerks
Aug 05, 2014 | Hotpoint Washing Machines
Hotpoint Wt540 1400 wont spin
check the machine washes ok if it does not turn the drum on wash check the motor brushes if drum action is ok on wash check the drain pump for blockages
Mar 06, 2014 | Hotpoint Aquarius WD63 Front Load...
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA 52P - My machine makes a lot of noise on the spin cycle. Any ideas?
definatly the drum bearing its common with those washers some repair men will do it for £80 thankyou
Jan 13, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wma42. drum not turning, brushes changed last november, have tryed a new motor twice still not turning... suspect pcb. what do you think.
Pcb is a distinct possibility but would check loom from board to motor as i have found many broken wires on wma series.
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WMA 22 drum not turning
Hi, common problem with this make of machine but easy to repair. Take off the lid and make sure it is un plugged from the mains...... You will need a pair of hook nose pliers to remove the carbon brushes from each side of the motor. They should be an inch long if not there is your problem.. Just replace and it will run.
Let me know how you get on..........
Nov 24, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Vibration problems
hiya
it could be a number of problems which are very common on the entire wma range.
1, drum bearings are really poor in these.
2, concrete block tapping, sometimes the bracket n the drums snap.
3, motor bracket snapped causing tapping.
i've found the plastic drums seem to be quite weak on the wma range to be honest so will more than likely be one of the above.
hope this helps
Jul 09, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
