Question about Olympus FE-360 Digital Camera
The lens will not soom or close all the way
The lens will not zoom or close all the way. it looks as if there is a piece that campe loose inside the lens
I have the 18-55mm lens that came with my D40 kit and found that it has a loose plastic piece that prevents the lens from it's zoom function. It can be seen through the back of the lens and has a tab of...
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Aug 10, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
White Spot
If this white spot is always exactly the same, but moves off the picture when you start to digital zoom and not optical zoom, there is probably something on the sensor. You mentioned that when zooming, eventually it moves. Are you in digital zoom mode at that time? (The switchover from optical to digital zoom is automatic, but you can disable it). Is this white spot blurry or sharp? Can you see fringes of the image at the edges? (This would suggest something on the lens).
If there is a piece of dust inside the lens ,you may be able to see it looking down the lens. How big is this spot?
Either way, if the camera is new, can you still return it?
May 28, 2008 | JVC GR-D244 DV Digital Camcorder
Lens does not lock into 50mm position........only to 60mm
It problably a loosen tiny piece inside the barrels. Do not attempt disassembly, you can ruin the less. In NY you can get the repair information in BH.
May 15, 2008 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Stuck on zoom
hi Susan, i think that your camera has lens problem and it is not fixed without opening the camera. just go to nikon shop. good luck...
Jul 27, 2006 | Nikon Coolpix 3200 Digital Camera
Olympus FE-360 Digital Camera Logo
105 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
