Lcd display on my samsung fax machine model sf-360 is not working
My LCD Display is not working, do you no if there is a battery to replace if so were do i look.
I welcome any advise, thanks.........
e-mail me at red_rock_55@hotmail.com
Have a great christmas
  • 417 Answers
Hi there there is no battery to replace it draws it's power from the power supply board. The only thing is that the LCD will need replacing as it is the complete control panel. You could try taking at apart and checking there isn't a dry point on the solder and re solder the LCD.
Try this but likely hood it that you will have to replace the control panel and in most cases this will out way the cost of the machine.
Hope this has been some help
Thanks J
Posted on Jan 06, 2008
Samsung SF-560R display "DOOR OPEN"
Check the cartridge and for a paper jam in front of fax.
Jul 29, 2011 | Samsung SF-560 Plain Paper Laser Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
SF 5100 model Fax machine is nott working, message displayed: Low Toner!!
you need to replace the toner cartridge if you open the front an take the cartridge out give it a shake to see how much is left in ..
Nov 25, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
LCD SAYS PAPERJAMMED
try to clean and oil the print head sharf. and clean the miler strip. this is the plastick pease with the black lins on. at the back of the print head carige
Feb 10, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung sf-340 user manual
Link to SF-340 User Manual:-
http://downloadcenter.samsung.com/content/UM/200609/20060925101938281_SF-340series_English.pdf
Reason you couldn't find it on Samsung website is they have it under "Multifunction Printers". ....?!! don't ask me!!
Gingan
Aug 27, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
SAMSUNG SF 360....connects but doesn't send
I Strongly suspect phone line.
If is it a DSL line you may need to filter is. If it is a digital line, then you shold switch to analogue.
I would start by just replacing the phone cord between the machine and the jack.
My other question is, are there any other devices plugged into the same phone line with the fax machine. A credit card reader, an answering machine? If so try removing them and see if there is some problem with a shared line.
But more then likely, you have a line with static, a bad groung. Low phone line voltage, current. some other line issue is very possible.
Suspect strongly a phone line issue
Mar 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Cannot read LCD display
No the display must be replaced. This is a common problem with that model!
Jan 02, 2008 | Canon LaserClass 9000L Plain Paper Fax
LCD Display too faint
Replacing the battery won't change anything.The LCD would have to be replaced, there are not any adjustments to change the LCD intensity.
Jun 08, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
100 people viewed this question
k24674
Marvin
Marvin
