Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I tried to clean the inside viewfinder of my canon 1000d and now it has some marks on it I am not sure if they are dirt marks or scratches how do I solve this problem
My Canon 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon Rebel xs 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy.
I can help you fix the BUSY Error on your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Mar 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The metering screen inside the viewfinder keeps flashing BUSY, and the display screen will not show anything.(Canon Rebel XS Digital SLR)
I hope that helps.
Mar 01, 2010 | Canon EOS Rebel XSi Digital Camera
Canon EOS - no data on LCD and viewfinder says busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Nov 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Jul 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99 comes on after I have taken a few pictures. I have tried cleaning with eraser as people have done and it still comes up with message.
I hope that helps.
Jul 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS says it's busy
The only problem with SD card download stuff is that the LCD screen has to be working. If that is part of the problem, how can the instructions be followed?
Mar 22, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 1000D wont let me shoot
It can be the cold or wet. try to keep it in dry place and change the battery.
Feb 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
311 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
