Question about Peg Perego John Deere Gator HPX Ride on Toy
Where is the fuse located on a childs john deere ride on tractor
    Genius:
  • Peg Perego Master
  • 1,508 Answers
There is a thermal fuse under the blue plastic of the battery and and another thermal fuse in between the battery and the foot pedal
Posted on Jun 13, 2012
  • 670 Answers
SOURCE: We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
Posted on Jan 03, 2010
  • 156 Answers
SOURCE: I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Posted on Apr 16, 2009
  • 850 Answers
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Posted on Aug 17, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
SOURCE: Where can I find rubber tires
I was wondering the same thing, can't find any rubber replacements and came up with a solution- use a rubberized undercoating for automobiles. It sprays on thick and provides more grip than the plastic wheels do.
There is more info on modifications here:
http://kidsbatteryrideontoys.com/gearheads-only/
Posted on May 28, 2010
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
John deere riding mower model D120 electrical diagram does it have a fusable link, if so where is it located
Yes, it has a 20 amp fusible link. It looks just like a 20 amp auto fuse. It's in a holder in the wiring harness. Typically it's found attached to the frame right in front of the battery holder.
Mar 05, 2015 | John Deere Garden
John deere 6400 no power
CHECK MAIN FUSE IF THE FUSE BOX IT IS THE FIRST ONE AT THE TOP IF YOU LOOK IN THE I THINK IS M1 FUSE 30 AMP
Oct 09, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
Where is the fuse located in the John Deere GT275?
Replacing Fuse
1. Lift hood.
M88565
2. Pull defective fuse (A) out of socket.
3. Check metal clip in fuse window and discard fuse if clip
is broken.
4. Push new fuse into socket.
5. Lower hood.
May 20, 2012 | John Deere Garden
How do I replace a hydraulic pump on a John deere 1050. Where is it located?
The pump is located in front of the engine.A coupler joins it to the front crank shaft pulley.
Nov 06, 2009 | John Deere Steel Chain/farm/tractor/john...
Battery location for sound on john deere utility tractor
The only John Deere tractor listed on Peg Perego's website shows that there is no sound. Are you sure the one you have was advertised with having sounds? It so it may help to have the model.
Oct 31, 2009 | Peg Perego John Deere Utility Tractor
Main fuse for jd stx 38
Go to the web site (yesterdays tractor.com) then go to john deer message board they can tell you everything you need to know to get the right one and where.
Oct 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Open Questions:
See all Peg Perego John Deere Gator HPX Ride on Toy Questions
Peg Perego John Deere Gator HPX Ride on Toy Logo
1,175 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
