Question about Dryers
The drum wont' turn when I push in the button
    Genius:
  • 1,474 Answers
Have you checked the power /fuse in plug///
Posted on Oct 01, 2009
When start button is pushed the motor will buzz but yhe drum wont turn
Turn power off ,Will the bowl(drum) turn freely by hand.
If not turn by hand the bearings are seized,
It will need a seal & bearing kit & maybe a shaft as well.
Jul 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Wont turn on and run the timer runs but the push button to start wont do anything
SOUNDS LIKE THE BELT ON THE DRUM IS BROKEN, LISTEN CLOSELY AND YOU MAY HEAR THE MOTOR RUNNING THAT DRIVES THE DRUM.
Mar 10, 2010 | Maytag SDE2606 Electric Dryer
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
Push start button,motor hums and wont sart until turning drum
worn out motor to weak to turn the drum,i see this all the time,motor on ebay run you$75 to $125,yout model number is inside the door-mike
Feb 11, 2010 | Whirlpool Dryers
Guitar hero world tour ps2 2 drums brand new wont connect
They are wireless. The drums take batteries in the panel by the keypad. The wireless transceiver plugs into the USB style ports in the front of the PS2. The transceiver has a picture of drumsticks on it and a button. When you push the button it searches for a channel. Then you need to push the 'playstation' button on the drums panel to sync them up. That should work for you.
Dec 25, 2009 | Activision Guitar Hero: Aerosmith
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Dec 21, 2008 | Dryers
Dryers Logo
Top Dryers Experts
