Question about Pioneer PRO-200 60" Rear Projection Television
I am having the same discoloration curve on the bottom of the screen and 3D effect on my pioneer elite pro118. Can this be fixed we haven't had the tv for that long and I hate to go get another because the furniture was made to fit around this unit?
    President:
  • 788 Answers
Your symptoms sounds like a damaged convergence IC.
This is a common failure for this particular television. You should have a red blinking power light on the front of your set that will blink 9 times and this is your solution to your problem.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Most of the time I have performed this repair for around $250.00-$300, but it may vary according to where you live. So repair is most likely the best way to go.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
As for the labor, I would make sure that the service center that performs the work has some sort of guarantee on the work that they perform. The better service centers will always have some sort of guarantee, at least 30-90 days.
I hope this information allows you to resolve this issue.
Posted on Oct 01, 2009
Hey there recently my screen just went haywire and i am seeing double and the second picture is red in colour,also the bottom of the screen is curved....what causes this and is it worth fixing?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 23, 2010 | Hitachi 50UX57B 50" Rear Projection...
Curved double image at bottom of TV and looks like a 3d image
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Pioneer Pro 700HD picture distortion
horizontal capacitor parts should be replaced...
Dec 31, 2009 | Pioneer PRO-700HD 64" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture looks 3D
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Samsung SP42W4HPX, black semi circle bottom of screen & 3D effect
sir/mam the problem of your t.v is weak picture tube,i have encountered for that kind of problem already.
Jul 31, 2009 | Televison & Video
Cleaning plasma screen
I wouldn't use the screen cleaner as I have seen it discolor the Front panel of the plasma before. Then the panel needs to be replaced.
Just put a small amount of water on a VERY soft clothe and clean it like you would a window. Do not spray onto screen as that can cause problems.
Mar 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer elite pro 118
if the tv is more than 10 years old no its not worth replacing the power supply.if its 5 years or newer yes it owuld be worth the money
Jul 17, 2008 | Pioneer PRO-200 60" Rear Projection...
Is this Pioneer Elite Pro 118 worth fixing?
You most likely have cold solder connections on the convergence IC's or on the B+ sources for the convergence. The longer you wait to have this simple repair done, the worse this will get and cost you double or maybe even triple of what it will cost now. Good Luck
Jun 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
392 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
