Question about Dryers
MY DRYER TUMBLES BUT DOES NOT HEAT, i THINK IT IS THE HEATING ELEMENT, BUT COULD IT BE THE THERMOSTAT?
    Genius:
  • 1,474 Answers
It could be one or both of these ,if you have a multimeter its simple to check
Posted on Oct 01, 2009
Testimonial: "answer was fast and very helpful,thanks alot!!"
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryers tumbles but there is no heat
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer tumbles and has airflow but no heat. it is a whirlpool
The odds are 50- 50, could be a faulty thermostat/s, or a faulty programmer/timer.
You really need to test heater with a meter to determine if faulty or not.
Hope this helps,.
Dec 08, 2009 | Whirlpool Dryers
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
