Machine is leaking around pump area ,is there a small plug that can come out or is missing?
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
It is perhaps pump seal if rust is present around here that would confirm...You need a new pump..
Posted on Oct 01, 2009
Mysterious coolant leak
Check out this few help links,in related to this types of problem.Click the link below :----Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
The plastic housing which goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
--------Car water leak around the Starter area and Bell Housing? http://schematicsdiagram.blogspot.com/2011/12/car-water-leak-around-starter-area-and.html
--------Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
---------This will help.Thanks.
Jan 16, 2012 | 2001 Dodge Neon
My lg washing machine model wm2277h is leaking water
these units have a variety of places they can leak from ...unfortunately you will have to gain access..the most common area for leaks in this model is down at the botoom around the drain pump area and or hoses..they spin so fast that all kinds of items can go thrrough the system a pierce the hoses or shatter the pump assembly... gain access to the bottom of unit and run a small load cycle and watch it you should be able to locate the problem and buy your replacement part on line .. good luck hope this helps....
Jan 03, 2011 | LG WM2277H Front Load Washer
04 Grand Prix
check your water pump for leaks. If its coming for the pump housing it will need to be replaced. Check the gasket area where the pump bolts to the block.. If water is not from the pump or around it check your hoses and clamps. check thermostat housing.
Jul 19, 2010 | 2004 Pontiac Grand Prix
Water leaking from under washing machine. Took off cover. Hoses ans water pump look good. Seems water is leaking on spin cycle above the transmission.
90% of the time the water leaks from either the drain pump module or motor, or through the centre seal and bearing.Couple of not so common areas are the various pipes:small holes in the drum:the soap dish etc. Possibly remove the lid and place the washer on 4 bricks and then run the machine so you can pinpoint the area.
May 20, 2010 | Washing Machines
Squeeling water pump, with coolant around the pump
Most likely you have a bad water pump. When the water pump fails it leaks coolant through small holes on the top and bottom.
Before you condemn your water pump clean the area and make sure the leak is not coming from another area.
May 07, 2010 | 1997 Chevrolet Lumina
1997 Buick Century Overheating
Have someone pressure test the cooling system - you likely have a head gasket leak
Apr 10, 2010 | 1997 Buick Century
Antifreeze leak in a 1999 plymouth voyager. Lookslike its coming from around oil pan. Water pump replaced last year.Also no heat
check all hoses .from thermostat to radiator to water pump. check heater hoses.if all is good .make sure your water pump not leaking around the gasket area.if all is good.core plugs could be leaking.
Apr 12, 2009 | 1999 Plymouth Voyager
Moffat Heavy Duty Washing machine pump leak
It should have a wax/plastic plug in it. Kind of a pressure relief valve. If it's missing - replace the pump. It cannot be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2009 | Washing Machines
Fisher and Paykel IWL12 leaking
First confirm the source of the leak. Dry the pump and all areas around it. Run a wash cycle and then check pump again. You should be able to see where the leak starts from. If it is definitely the pump, it is easy to remove. Take off wire plug & earth wire. Hold out the white plastic clip on the side of the pump and rotate pump quarter turn anti clockwise. Pump will then come out. Do the reverse to put pump back. Make a note of which way the pump faces before you take it out. Also, make sure power is unplugged before you do any work.
Sep 06, 2017 | Fisher and Paykel IWL12 Top Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
