I replaced a drive belt on my Amana model ALW480DAWabout a month ago. A couple of days ago it got stuck again and starting amoking but I stopped it before it broke and was able to spin the water out. Any ideas on why it's getting stuck?
  • dkthelen Oct 08, 2009
    Amana washer model alw480daw doesen't have solenoids,so your suggestion wasen't any help. I had to call a repair man. The probem was the bearing assembly was leaking and the bearing lost it's seal and lubrication, so after it would spin it got hot and would stop while the motor spun and melted the belt.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Sounds like drum pulley / drum is sticking could be sock in drum, Can you turn it by hand , is it noisy...The drum sticks and motor keeps driving which burns out the belt..Hope that helps you...
Posted on Oct 01, 2009
  • Gerry Harvey
    Gerry Harvey Oct 08, 2009
    Not sure why comment on solonoids was sent to me as i never mentioned that but was glad to be close on the fault..Very pleased to hear you got to root cause and now repaired...Hope all is well.
    Sergeant:
  • 247 Answers
Lost connection with you on first live chat,i think microsoft updates i recieved earlier are to blame,tracked your name and im here,remove the belt,spin the water pump pulley should be free and smooth,try to wobble pulley to check bearing wear,you should see two mechanical arms that are controlled by solenoids,they switch the functions from wash to spin to discharge water,ect,reinstall the belt run it through the cycles watching the solenoids they should move the arms smoothly and hold their position until the next cycle is reached,i thnk once you observe thid it will be obvious what is wrong,sometimes the solenoids fail and cant maintain position ,sometimes the mechanical levers get worn an jam up during the switch,let me know what you see,send me a comment if you have any questions,sorry about the droped chat session ,i am currently resolving the problem,aloha from maui todd0708
I have a 2002 Hyundai Sonata 2.4L with about 143000 miles. About a month and a half ago I was driving home going about 55mph not uphill or downhill. All of the sudden my car jerked hard once and the check...
The knock sensor is used to detect engine vibrations caused by preignition or detonation and provides information to the ECM, which then retards the timing to eliminate detonation.Here's a link on how to test and replace.Here's the sensor.
Sep 05, 2013 | Cars & Trucks
Hello, My dryer was working fine a few days ago and just yesterday it stopped working. I pressed the stop button and there was no power. the Filter connecting the dryer to the wall is not blocked with...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 14, 2011 | Amana NED5100TQ Dryer
I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
May 01, 2010 | Amana NDG7800AW Gas Dryer
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
Just got alternater replaced a couple of months ago and its starting to squeel again like last time and the battery light keeps flickering on and off
The alternator drive belt is loose or worn out. If the alternator is driven off a serpentine belt then replace the belt. Inspect the serpentine belt tensioner and replace if necessary. On an 18 year old car it is more than likely defective. If it is driven off a standard drive belt then adjust the alternator to tighten the belt. Inspect the belt for fraying and or cracks and replace if you see any.
Dec 17, 2009 | 1991 Honda Civic
2003 Neon air coditioning shutter
the AC servo that kicks up the engine idle speed when the AC is no..Is stuck or faulty...Replace it.
Apr 05, 2009 | 2003 Dodge Neon
Squealing NOISE possibly from fan belt
Belts stretch from new. Try to tighten them again. Hopefully the are not glazed or this may stay with you.
Dec 14, 2008 | 1988 Dodge Grand Caravan
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
