Sound/Speakers My speakers are not working on my Protron TV. I do not have it on mute and I show that the speakers are on. Help!! What things can I do?
  • Albkat Jul 22, 2008
    coby tf-TV1511 speakers quit working on the set, just crackling sound.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
If the problem is not from user part. flat panel televisions require authorised service personnel. if the problem present in the interior of the t.v system .Call service personnel. there is no rectification process frm user part. thank you
Posted on Dec 20, 2007
PROTRON 26 INCH TV SOUND BAR
On some TVs, you have to turn off internal speakers to direct sound to external audio connectors.
Sep 29, 2017 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
Headphone jack in tv has stopped working when putting speakers or headphones in is making a loud clicking sound. Is there anyway to connect speakers or headphones to the tv without using this jack? Have...
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Nov 14, 2017 | Electronics - Others
My Protron tv does not have any sound, what could be the problem?
hi,
First of check that is the MUTE is on or not. Press the mute button on the remote to cahne the setting of mute.
the also the problem remains. you tvs speaker or the audio output ic have some problem. first of all check the speaker. Is it ok or not. for checking the same u have to open the tv. if you can then,
Remove the rare cover of your tv. find out the position of the speakers. remove the speaker connection from the board. It will be a socket you can easily remove it by pulling it.
Then take a 1.5V cell. The speaker will have to connectors from which the wire is connected. connect cell between it, if you hear a small cracking sound from the speaker the it is ok if not the speaker is faulty.
if the speaker is ok the the audio out put ic (integreted circuit ) will be faulty. u can see the audio output ic near the speaker socket from where you have pullout the wire. check the number noted in its top and bring a new one and replace it . for removing and replacing the audio output ic you should have soldering iron , de soldering pump and solder.
ok
Jan 16, 2011 | Protron PLTV3250 32 in. LCD Television
We had a thunder storm on Thursday lightning struck the dish and both t.v.s went off. my wife called dish they came and change everything,know mt t.v in the living room works has volume my t.v. in the bed...
. Make sure that you don't have mute on, and make sure your TV speakers are turn on. Go to menu and see if there is a way to turn your internal speakers on. If you can't fine anything , then your audio processor could be locked up, and if you unplug your TV for 30 MIN. it will reset the processor back to normal. Good luck and have a nice Day.
Oct 16, 2010 | Protron PLTV-37 37 in. LCD Television
Tv has no sound
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 20, 2010 | Protron PLTV-32 Television
Our Protron pltv 3250's sound just stopped working. The tv works fine but no sound.....
Check ur speakers connections,check the board that have ribbons connections to speakers.Reset all tv modes to factory mode see what happen also?
Oct 31, 2009 | Protron PLTV-32 Television
Speakers
may be u r speaker r dammaged....check them by connecting with other device like...walkman...tv...etc.
if speakers r work properly on tv or walkman...now plugg u r spkakers again.....(check u sound setting 1 st ..speakers may be mute)...if still having try to update u r audio driver...
Regards & best of luck
for more information on this topic u can mail me too
sigma_shiva1@rediff.com
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
Nov 15, 2007 | Audio Players & Recorders
Speakers maybe...
Re: Protron LCD tv - READ THIS #631 I work for Protron.
We are in a big dispute with the Chinese factory that makes Protron LCDs. No replacement parts will be coming, ever.
There are no remotes and no power supplies available.
PROTON has already won their lawsuit which prevents us from selling under the name PROTRON. As soon as they pay the bond, we are shut down.
Our management is in chaos. Our customer service dept is non-existant. Our rating with the BBB is 'F'. The product is cheap because it is made with cheap parts. Getting the picture here?
If you buy a Protron LCD, you are completely on your own.
Good luck.
Oct 21, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
