Question about SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive
My cruzer is wroking fine except when i try and use "my computer" the drive doesnt show up. In any other program i can save to it and it shows up...just not in "my Computer"
  • 1 more comment
  • snow_faery Oct 01, 2009
    The cruzer still didnt show up.:( but thanks for the help
    if i re formatted the drive...wont i lose what i have saved on it?
    ok, so i have just realized that since my computer has multiple profiles on it...in the one i was using (guest) the drive doesnt show up in "my computer" but in every other profile it does. so i am assuming this is a security feature so guests cant easily access the removable drives.
    President:
  • 1,187 Answers
In [My Computer]
select [View] from the top menu row
[Details]
[View]
[Arrange Icons by]
[Type]
[Arrange Icons by]
Checkmark on [Show in Groups]
The cruzer will show up as
"Devices with Removeable Storage"
Posted on Oct 01, 2009
  • 17 Answers
I would try formatting the drive again.
1. Plug it into your computer. 2. Right Click "My Computer" and choose "Manage" 3. Go into "Disk Managment" 4. Right Click the Cruser Volume and choose "Format" 5. Choose NTFS and Default, then click OK. 6. Unplug and plug back in. 7. Check My computer. 8. Let me know.
SanDisk Cruzer Blade is not showing data. The drive shows up in 'My Computer' but data is not showing.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I plug in the flash drive it lights up but doesn't show up as a drive in "my computer". If I start the device manager (which shows the cruzer device as a funtional drive), disable it and...
STEP 1 - Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: The Cruzer might show up under several places under Device Manager such as:
1. Disk Drives
2. DVD/CD-ROM drives
3. Universal Serial Bus controls as USB Mass Storage.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
SOLUTION 4 -
There might be a conflict in drive letters, see Resolving drive letter conflict.
Oct 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
How can i save a program to the cruzer micro 2gb from my computer?
Hi:
You can't save a program that is installed on your computer, but there is an option. You can install a program to your cruzer, or if a program is a downloaded program, you can download and save it to your cruzer, before you install it. This is like this, to prevent software piracy... Otherwise, I could steal a program from any computer, and copy it to a flash drive...
Nov 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 4gb cruzer flash drive and its not working
Okay. Try putting it in on the back of your computer and tell me if it lights up at all, even if it flashes once.
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
Mar 16, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Cruzer Says It's Full...But It's not!
this will clear your drive so make sure you remove what you want saved before you do this. you need to reformat your drive. plug it in. go to my computer. right click n your drive. click format. there might be two choices it doesnt matter which. i did mine FAT32. i checked quick format. then clicked start. ten seconds later empty drive.
Mar 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk crezer 4GB micro wont work
Try this,
Note:I assume you are on win XP.
Right click on my  computer and click manage.
Now on left side please select Device manager and look on the right side if you have any device that says "Unknow Device" or any device that is showing an Exclaimation Mark. If any of this exists then right click on that and uninstall. After this unplug your Flash drive and restart your computer and try inserting flash drive if it works or not.
If not, again go to device manager and expand an option that says "Disc Drives". Please check if it shows anything related to your Cruzer Flash Drive. If it's there, then go to Disc Management that will be there on left side of this same window. There, you need to look for your Removable disc and right click on it and click change drive letter. Now choose a different drive letter preferable one of the last alphabets like Z. After this click OK and now try going to my computer to check if it appears or not.
Moreover, if none of these solutions work please get back to me with some more info like if you have U3  on your Cruzer that comes preinstalled on your flash drive and the version of your OS.
Nov 23, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Doesnt open
MY sendisk pan drive is not being recognized by any of the computer .it is showing a message of malfunctiong plz suggest a solution and resolve my problem.
jawahar gaur
Jul 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro 2.0 problem
Should show up in "My Computer" as a removable drive with letter designator. Then it is simply a matter of drag and drop to copy files using the mouse. If XP doesn't recognize the drive, put it in another USB port, and or try it on another computer. If it doesn't show up then, take it back to the store.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 2GB USB 2.0 Flash Drive Logo
94 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
