How do I clean the filter on a Bosch Exxcel washing machine? White washing (especially bedding) comes out of the machine with dust like particles all over it that are very difficult to remove.
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Is this dust or OIL, if its oil its perhapsdue to faulty drum bearing /leaking is the machine noisy on spin ? this is an indication of this...
Posted on Oct 01, 2009
How do I open the filter on Bosch exxcel 1600 express washing machine please?
Open panel on lower right front of washer. Unscrew filter. Clean. Replace. Water will come out so have a plan.
Mar 23, 2015 | Bosch Washing Machines
What does the fault code E18 mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Bosch exxcel 8 washing machine, display dead when you turn on and door locked, fuse is fine..
probably the main board, you need a proper machine expert these day to reset the codes, designed so only they can do it.
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Manual
F18 is time out on drain, check the pump filter for foreign objects (coins etc-behind flap, bottom right of front kickplate) and also check for blockages on outlet hose (especially if connected via spigot, directly to sink U bend)
May 03, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Hi There, the quality of wash on my Bosch dishwasher has reduced (especially on top shelf) to a point where it is almost not worth using. filters etc are clean and no issues with water enttering the...
All the jets must be clean especially the drive jets at the ends of the wash arms, these drive the arms around thus allowing jets of water to reach every piece of crockery.
Aug 02, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Jul 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
