Recording from AV
Hello, can you tell me how I record from AV?. I have just bought a funai VHS, and cant figure out how I do it.
  • 579 Answers
Cheaper VCRs will automatically switch to using the AV inputs if a cable is phyisically plugged in. Better units give the user the option of leaving the cables plugged in all the time but you then have to either flip a switch or go into the onscreen menu to select this input. (May be called A/V, or AUX, VIDEO, or even a high channel number like 99)
Posted on Dec 29, 2007
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Jul 16, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
JVC COMPACT VHS CAMCORDER MODEL NO. GR-SXM250U
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Feb 20, 2009 | JVC COMPACT VHS-C CAMCORDER
Sv2000 dvd recorder only
go into setup set input to ch 3
Nov 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
Recording dvd from vhs
you may not need a remote to dub a vhs tape to dvd.
look on the front of the recorder. see if there is a arrow showing dubbing vhs to dvd/ dvd to vhs. since you do not have the manual, you'll probably have to play around with it a while to figure it out. you will also need to know which format the dvd will record on. [dvd-r,dvd-rw,dvd+r,dvd+rw or ram] you can look up your recorder brand & model # online, then search for a manual you can download.
good luck.
wg
Feb 13, 2008 | LG RC797T
RECORDING
On most VCR/DVD Recorder combos there is a quick dub button that you must select the source. Ifyou are recording from a VHS than you need to make sure the button is pressed so that VCR is displayed or lighted or whatever the unit does. If its on ??? Then perhaps its telling you that it is set to record of the DVD which it obviously can't.
Nov 04, 2007 | Zenith XBR716
Recording
here is a link to download the manual for your vcr - http://www.usersmanualguide.com/funai/video_cassette_recorder/6240ve - hope this solves your problem.
Sep 20, 2007 | Sylvania 6240VE VHS/S-VHS playback VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
