Question about Acer Aspire 5610-4648 Notebook
Laptop shutdown while in use. Plugged in to power source but would not restart. When power button is pressed, laptop comes to life for 2 to 5 seconds and then goes dead again. What could cause this?
    Novelist:
  • 110 Answers
If you let it sit unused for hours, would it work properly for a while? It sounds like it is overhaeting. So when it shutsdown and you try and turn it back on, it wont becuase it is too hot. But if you let it sit for a while it will turn on for longer because it has had time to cool down.
If this is the case then it's just overhaeting. Could be caused by a bad fan, or the fan could be clogged with dust. Try these steps to determine if it is overhaeting or not.
If it wont turn on again AT ALL ever, only 2 to 5 seconds no matter what, then you probably fried something. Try taking out one of your memory sticks.... and then Hard Drive. See if it works. Something on the motherboard could have fried if it still wont turn on.
Try taking out the battery for a few minutes, then jsut turn it on with the A/C only. Do some troubleshooting to determine what might be the problem.
Posted on Oct 01, 2009
Lenovo R60i wont turn on, power lights come on, go out when power button pressed
Take out the battery temporarily. Wait 30 seconds. Connect the power cord and try to start without the battery. If it comes on, put in battery while laptop is running .
Aug 01, 2014 | Lenovo THINKPAD R60I LAPTOP LCD SCREEN...
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Laptop is run and start but no display
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
How to restart!/reboot a packard Bell laptop?
Hi bjrnariverse,
Hold in the Power button for 10 seconds, this will cold shutdown the laptop. Then simply start it up again by pressing the Power button.
Kind Regards :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 21, 2011 | Computers & Internet
How do you reset your latptop?
You can perform a hard reset by pressing and holding the powered button for 5 seconds.
Please leave feed back if this helped you :)
Nov 12, 2010 | Computers & Internet
My acer aspire 4520 starts the comes off a few seconds after pressing the power botton
hi, yes the laptop will shutdown if you press power button.
it send command to OS that it required to shutdown in emergency so it shutdown in force. so do not shutdown by pressing the power button. use start> shutdown option.
i hope this will resolve the issue.
Jun 23, 2010 | Acer Aspire 4520 Notebook PC
Thinkpad T500 lenovo laptop will not start but battery power light is one
  1. Shutdown laptop.
  2. Remove battery, other external peripherals connected, disconnect from ac adapter.
  3. Press and hold power button for 10 seconds to drain power.
  4. Restart laptop.
May 20, 2010 | Lenovo ThinkPad T500
My Lenovo laptop show message "Plugged in, not cha...
  1. Shutdown your laptop, remove battery and power adapter.
  2. Press and hold the power button for 10 seconds to drain the power.
  3. I f still no go, change your battery.
Hope this works...
May 20, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Feb 12, 2010 | Dell XPS M1530 Laptop
Acer Aspire 5610-4648 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
