Question about HP Color LaserJet 2600n Printer
Streaks and smudges
Our printer has been printing unwanted streaks and smudge in red, yellow and blue. It was infrequent at first but now seems to be happening with every document even if the document is just plain b/w text. A few months back I replaced the HP cartridges with some cheaper cartridges I found on the internet and Im wondering if maybe that is the cause of the problem. If anyone has any idea about whats going on here, Id appreciate your feedback. Thanks.
I have to agree with dlawe2003 on it being a possible transfer belt. unless the toner is bad and it's unlikely all of the toner is bad at once.
Posted on Oct 15, 2009
  • 81 Answers
Have you checked and replaced the transfer belt. It will wear over a period of time and create image defects
Posted on Oct 13, 2009
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Prints smudges in many colours
the most common causes for multi-colour smudges and streaks are the laser-module (or scanner) and/or the photoconductor unit (also called drum).
Apr 20, 2010 | HP LaserJet 2820 Printer
Blue color appears pinkinsh/now stripes and smudging
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Nov 20, 2009 | Xerox Phaser 8400 Laser Printer
Pringed Pages are coming out with yellow and blue smudges on edge
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Jun 02, 2009 | Lexmark C534dn Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
HP Color LaserJet 2600n Printer Logo
407 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
