Question about Fusion Digital designs EN-AM6004 Car Amp
Red light on fusion amp?
Red light on fusion amp, no sound cuming out of speakers?
    President:
  • 846 Answers
This is a rather common problem. The red light indicates it is not correctly getting power.
So trace your power wire from the battery--> check the fuse on the wire if there is one---> to your amp. If that is all in working order next move onto the ground wire.
Make sure it is sparking on the surface that you have it grounded at. If it does not spark when you touch the ground wire against that surface then you are not correctly grounded. It should be bare metal, something connected to the cars frame.
Try this and post back if you still need additional help. Thank you for choosing Fixya!
Posted on Oct 03, 2009
Fusion AT 1100 Flashes green power light once and then shuts down. Hiya I have checked all the wires again but no luck. I love this sub and do not have money to buy another one. Please help :-(
Amp is going into protect mide. This means either the amp has an internal fault or the speaker is blown. Pull the speaker out and disconnect the wires from it. Make sure they don't touch. If the amp powers up fine you know the speaker is bad. If it doesn't the amp is bad.
Jul 26, 2016 | Fusion Car Audio & Video
Do I need a amp for Fusion MS-BX402 speakers
the reason for running an amp is becauze ur running your volume so loud you are getting distortion. Btw, its the distortion that damages speakers. If your happy with the sound then you dont need an amp. If your running your radio "full tilt" to get your sound, think about adding some power.
Dec 01, 2014 | Fusion Car Audio & Video
I have a 900 watt amp and 2 12" fusion subs.will this sound good?
Yes. It should sound good.
Try in the trunk, facing the back of the seats.
A simple Infinite Baffle/Free Air setup, should work fine.
Jan 04, 2010 | Fusion FEW12PK Car Subwoofer
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
Fusion amp soild bold red when the radio comes on
The amplifier is in protection mode.
3 reasons for this...
  1. Improper Load/overheat - wrong impedence voicecoils or wired improperly below rated impedence.
  2. Grounded Power - speaker wires touching, power wire touching ground,
  3. Internal component failure.
if the amplifier will still not go out of protect mode after removing the speakers and jumpering the remote wire to the + terminal - your amplifier needs professional repair.
Thanks for using FixYa - a good rating is appreciated for taking the time to answer your FREE question.
Jul 08, 2009 | Fusion Digital designs EN-AM6004 Car Amp
Fusion amp . the green light is on but when i turn the volume up the red led light is flashing but gleen led is still on and sub goes a quiet bass sound .
First your need to make sure that the amplifier is grounded properly. And verify that all other connections are as well. Unfortunatelly, i wouldn't be able to help you because i need to be in front of it to troubleshoot. Hope you fix it.
Nov 11, 2008 | Car Audio & Video
Fusion sub n amp dont work
didi u check ur fuses in the amp..if not there check the fuse under the hood on your power wire.i had the same problem
Jul 27, 2008 | Car Audio & Video
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Fusion Digital designs EN-AM6004 Car Amp Logo
296 people viewed this question
Top Fusion Digital designs Car Audio & Video Experts
xxxxxx xxx
Are you a Fusion Digital designs Car Audio and Video Expert? Answer questions, earn points and help others
