Question about Brother HL 1240 Printer
When i print there is a vetical faded space/line down the page. i have changed tone but it does not help. any suggestion?
    President:
  • 2,306 Answers
Use a dry towel with the toner removed, and wipe the 1 inch wide window above where the drum goes. Toner and fingerprints on that glass will cause the problem you are seeing.
Posted on Oct 01, 2009
Testimonial: "thanks that worked"
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Faded lines of black across part off printed page
please you used the colour printer ? if yes then your check the csrtridge a refeling the towner and service the cartridge and service in printer and aply the print is ok.
Sep 22, 2009 | OKI C9300 Led Printer
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
3410 Oki printer
If your print fades in then out every 5-6 lines, your platen probably has flat spots on it. This can be caused when someone forget to perform an alignment on a PH.
To run a test page you can power off the printer. Hold down the LF key and power on at the same time, this will print a self test.
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Vetical lines printing on page
If the lines are blue, check the color PCU.
Oct 25, 2007 | Ricoh Aficio CL3500N Laser Printer
Brother HL 1240 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
