Question about Zebra Z4Mplus Label Printer
Head cold - Zebra Z4Mplus Label Printer
    Champion:
  • Zebra Expert
  • 285 Answers
Run some labels and the warning go off. it is not a problem
Posted on Mar 26, 2011
How to torque the head on ford 5000 tractor
The manuals will tell you the head torque is 105 ft/lbs , but torque them to 115 ft/lbs. There was a bulletin a long time back dealing with this. Also make sure ALL head bolts have a hardened washer on them.Part # 377490S. As a rule I'll set the intakes at .017"cold on the intakes and .020" cold on the exhaust. It wouldn't hurt to retorque the head and reset the valves after 20-25 hrs.
Nov 06, 2013 | Ford 5000 Tractor
Anitfreeze leak around the head side of a 93 cadillac fleetwood brougham
sounds like head gasket with the info given. check oil cold and antifreeze cold. Do you see traces of water in oil, or oil in water? I would get a coolant pressure test done to pin point it.
Jan 19, 2013 | Cadillac Fleetwood Cars & Trucks
TOYOTA 2.7 COLD START PROBLEMS
I just replaced the cyl. Head gaskets in my 97 toyota 4 runner 4cyl. And i having problems to start the engine when is cold, when is hot start like new
Jun 07, 2012 | 2007 Toyota Hilux 2.7
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
After 40 mile ride engine started to overheat. Heater blew cold air.
when the heater blowes cold you are low on anti frezze, the system is designed so that when the system gets low on coolent the heater will blow cold it is a waning for you to know some thing is wrong, i dought it is a head gasket but it might be, you need to have some one pressure test the cooling system, my first thought is to have someone take a close look at the weap hole on the water pump. we see alot more waterpump leaks then head gaskets on the jeeps.......good luck
Jan 31, 2012 | 2005 Jeep Grand Cherokee
How to fix heater in 1999 chevrolet suburban 2500
It is doubtful the head gasket. Other problems would show up like loss of water into the oil etc.
Check there is water flow through the heat exchanger.
Sep 05, 2017 | 1999 Chevrolet Suburban
I used my PD-150 to videotape an alpine ski race recently. It was snowing pretty hard and damp out. I also forgot to cool the camcorder slowly to avoid condensation. Anyway, the entire tape was a loss as I...
Moving from warm to cold is never an issue, moving from cold to warm does the damage unless one removes the tape when cold and them waits for the condensation to subside.
Head cleaning fluid is for stationary heads only! Use a piece of clean paper and rotate the head against it with no up down movement or you will break the head off.
May 15, 2017 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Zebra 140 head cold on led display. What does this mean?
you need to run some labels to warm up the printhead. its not a problem, its just a warning. you can disable fthis warning from the setings.
May 10, 2010 | Zebra Printer 140-751-00000
How much lb ft. of torque should i put on the cylinder head bolts of a 1992 toyota hilux surf turbo diesel 2lt engine.
what is the valve clearance and cylinder head torque for toyota 2lt diesel engine
kasim
Jan 25, 2010 | 1992 Toyota 4Runner
Zebra Z4Mplus Label Printer Logo
222 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
