Flooding problem in a AWM8146
Hello I have a whirlpoo AWM8146 and have a problem.
The maschine keeps filling with water and never stops, after a minute or two i get error code F09 (over flow??) not so strange half the maschine is full then...
Does anyone have a tips for me??
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
Sounds like pressure switch or feed hose to the switch blocked or faulty
Posted on Oct 01, 2009
The water will not go into tub, keeps overflowing and flooding my laundry room
If the water will stop filling when you stop the machine, then you need to replace the "pressure switch" on the unit. Here is the part to order.
If you have to turn the water off at the faucet to get it to stop filling, then you need to replace the "water inlet valve" on the unit. Here is that part to order.
Nov 09, 2012 | Maytag Neptune MAH5500B Front Load Washer
My GE washing machine keeps over filling, flooding the room if we don't stop it. Where is the mechanism that measures and turns of water?
If the machine starts to agitate and the water does not shut off replace the water inlet valve. Now if the machine fills and does not agitate,then clean the pressure sensor tubing and the line coming off the tub. Hope this helps Tim
Mar 02, 2011 | Dryers
Doesn't seem to fill with water. Maytag MDB6000AWW
if the washer is not flooding the floor or room turn it off the pull you dain hose up from the drain tube you should here water coming out.once the water stop keep the hose up but do not pull it out of the wall and restart the washer it should then fill up to the proper level and then start washing. i hope this helps please let me know
Sep 27, 2009 | Maytag Dishwashers
Washer keeps filling up with water and it will not stop
the main drain hose may be stuck to far down inside the drain tube.if the machine is not over flowing and flooding your plaace.then pull the drain hose up to the level of the control head.with the machine off,you should here water running out once that has stopped restart your washer put keep the hose up and it should stop filling when it gets full.
Sep 19, 2009 | Washing Machines
The washer water won't turn off once it has filled for all three load sizes.
Might be the water inlet valve at the back of the machine where the hose connects too, replace the valve and see if that fixes the prob
May 09, 2009 | Admiral AW22 Top Load Washer
Washing machine overflowing
Sounds like the water level sensing sub-system is malfunctioning. If you want to pursue this further, let me know.
Apr 29, 2009 | Siemens WFXD8400UC Front Load Washer
Flooding > water container empties all water in one shot
Your docking from the Water container into the maschin is defect.
Call the coustumer service.
Dec 25, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Whirlpool Icemaker flooding freezer
how much water and did you have to shut off the water supply to stop it
Mar 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
