Question about Kodak Cameras
Sd card cannot be read & internal memory of camera cannot be read
    President:
  • 1,187 Answers
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Posted on Oct 01, 2009
What does back-up to sd card mean?
the camera has internal memory and also will have the option for external memory. If you have a sd memory card in the camera you can backup the internal memory to the sd card.
Then you can remove the sd card and put in a new sd card and you now have an sd card with your precious photo memory's copied from the camera internal memory. You may have a camera that allows two sd cards one for the photos and one to back up the photos. If you had your camera stolen or lost you would lose all the photos on the camera but with a backup sd card you still have the photo files. Also a p.c with a card reader device could read the files on the sd card and you could copy them into a cloud storage on the net or onto a network storage device or onto a usb portable drive with 2 terrabyte capacity .
https://en.wikipedia.org/wiki/Secure_Digital
Jan 29, 2016 | Cameras
I installed an SD card into my Kodak Easy Share C183 camera but it won't allow me to take pictures it keeps saying internal memory is full what do I do I can't find the answer in the manual
it seems that your camera is still on internal memory, if your camera was off when you inserted your sd card, ( it needs to be off when inserting it) it should automatically switch over to the sd card.
I'm not sure with yours, but with mine( I have an older version ) I can go into settings & switch it back & forth from internal memory & sd card.
here is a link to an extended user guide for your camera.
http://resources.kodak.com/support/pdf/en/manuals/urg01133/C183_xUG_GLB_en.pdf
Jan 30, 2015 | Kodak Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Will not format memory card
    How to format the memory card in my camera? NOTE this will delete all existing data on your card.
    1. Do the following:
    2. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
    3. Turn on the camera.
    4. Press the Menu button, then go to the Setup Menu.
    5. Scroll up or down to the Format option, then press the OK button
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C913 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Camera does not read SD Memory Card
    thank you so much this worked great it solved my problem thanks.
    Oct 31, 2008 | Kodak EasyShare M863 Digital Camera
    SD CARD
    If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
    Feb 10, 2007 | Samsung Digimax S500 Digital Camera
    Cameras Logo
    200 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Jerry Greenberg
    Jerry Greenberg
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
