Question about HP LaserJet 3050 All-In-One Printer
The menu got switched to russian and I don't know how to get it back to english . It's an hp 3050 laserjet
  • 329 Answers
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Posted on Oct 01, 2009
I have just set up HP DSKJET 3050 ALL-IN-ONE but I couldn't select English language and it showing Korean. I can't understand it and I don't know how to change it to English.
Press MENU and then 2.
press < or > to select location and then press "check mark"
Press < or > until correct location appears. Press "Check mark"
Press 1 to confirm.
Printer should now reboot.
Apr 02, 2011 | HP LaserJet 3050 All-In-One Printer
How do I change my HP 2600n Language back to English
A. To change the display language back to English, please perform the following steps:
1. Press the right arrow 2 times, press the OK button (you should be in the System Setup menu).
2. Press the OK button again (you should be in Language).
3. Press the right arrow until you see something that may be English, press OK button. The menu is a continuous loop, so if you miss it the first time the option will return.
May 22, 2009 | HP Color LaserJet 2600n Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP printer needs to switch back to english
Try a cold reset..power the machine off. While its powering on hold the check /go button down when you see the memory counting when lights are all lit up let go.
Aug 26, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 3030 printer/scanner/fax Language has
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
Mar 25, 2008 | HP LaserJet 3050 All-In-One Printer
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
