Question about HP Pavilion m7580n PC Desktop
Support memory ram of 2 gb for each slot of the board
  • 20 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00714578&tmp_track_link=ot_recdoc/c00757531/en_us/c00714578/loc:1&lc=en&dlc=en&cc=us
Everything I read about this motherboard says Max is 4GB, 1 per slot. You might be able to use 2GB in two slots, but I dont think your going past the 4GB barrier.
Its not the HP way...
BUT Toms hardware gave this machine a "powerhouse" rating.
Posted on Oct 01, 2009
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I want to know how many RAM memories(in GB) can reach the motherboard M810D
You can calculate it yourself.
a = the number of simm slots
b= the maxium value of ram chip the moher board allows
there for the total is a * b ram memory
eg 2 slots , 512mb max memory chip size = 1024mb memory max
Aug 17, 2010 | Computers & Internet
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I had a 1 gb ram on the my Asus P5VD2-MX mother board and tried adding 2 gb to the 2nd slot but computer alarm sounds. I swapped the 1 gb to the 2nd slot and alarm sounded again?? It seems the 2nd slot...
 you put the 2 gb in the first slot(that's the default setting on all motherboards-the biggest memory is in front) then in the second slot the 1 gb after that restart if you get the same sound the remove the battery on the motherboard and put it back to reset the bios after that restart.
Dec 29, 2009 | Computers & Internet
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
I want to upgrade my ram for my pc...atmost to how much i can upgrade and in each slot individually how much capacity of ram it supports ...my motherboard is 915glvg
i would like to inform you that *********** board supports upto 4 gb ram and 2 gb in 2 slots will be the best combination but depends on the OS you are using if its 32 bit XP or Vista it wont accept more than 3 gb so if you wish to use your system in full throttle mode upgrade you r OS to 64 bit XP or Vista and enjoy all 4gb standards that you actually wish to but even 3 gb is like playing with wild fire that will be really too fast processing speed and thrilling performance that you expect.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Intel D915GLVG Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
HP Pavilion m7580n  PC Desktop Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
