Question about Acer Aspire 3000 Notebook
Sound program My Acer Aspire 3502LCi notebook has no sound. So I checked under sound in the control panel and it says there is no sound device. I inherited this laptop and I wonder if it was deleted.Does anyone know where can I find it and re install it?
    Scholar:
  • 102 Answers
Go to this site and download the RealTeck Audio drivers, make sure the type of the hardware Audio device is installed on your machine first please (you can check in the hardware tab, right click my computer, properties, hardware, device manager)
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=5384390&CFTOKEN=59349234
Also you need install system software from here if you do not have it:
http://global.acer.com/support/download.htm
Hope that helped Regards!
Posted on Dec 20, 2007
Just bought a acer aspire 3003 off ebay and it has no sound. also I have tried 2 adjust the volume thru the control panel and it says there is no audio device. How can i fix this?
Check for your sound card first. Click "start", click Control panel, double click system, click the hardware tab, click device manager, click the + sign next to (sound, video and game controls),(take not of the maker and model of your card) if this shows a sound card, right click on it. Click properties, check under status. Do you see "this device is working properly" if not, click driver tab and try rollback driver and then update driver. If no sucess take this link to acer and select your audio driver. (This takes you to downloads for the Aspire 3000). Check to see that this matches your sound card(maker and model noted previously), it may have been changed.
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Mar 10, 2010 | Acer Aspire 3003WLCi Notebook
No sound on Acer Aspire 3000
Possible culprits: the drivers for the sound card are not installed, the sound is muted within Windows, or the sound card is damaged.
Start with the easiest thing first. See if your sound is muted. Access the Control Panel and go to Sounds. If the Mute box is checked, uncheck it.
If that fails, check to see if the Device Manager is showing disabled or nonfunctional devices (usually a device with a red X or a yellow dot with a black exclamation point). If its a red X, right click on the device and choose Enable. If its the exclamation point, the drivers are not installed. The easiest way: use Windows Update and let it scan your machine. Install any audio drivers it finds (do the audio driver ONLY).
You'll need an external solution if the device is defective. If the notebook is under warranty, contact the manufacturer for options.
Good luck to you.
Sep 24, 2009 | Acer Aspire 3000 Notebook
No sound
Go in control panel look for sound and open it.See if sound is enabled if not do it in there.Go to start/all programs/accesories/entertainment/sounde and adjust the volume of the sound in there.Go to my computer /properties/device manager/sound device and see if sound driver is up to date or if it has a yellow '?'' next to it.If so update the driver.
May 31, 2009 | Acer Aspire One PC Notebook
Acer Aspire 7720 built-in microphone not working
In the sounds control panel, right click in the area which should show recording devices. Select 'show disabled devices' and bingo!
Feb 25, 2009 | Acer Aspire 7720 Notebook PC
How to turn-on/function mic in my acer aspire one pc notebook?
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
Jan 31, 2009 | Acer Aspire One PC Notebook
I have an acer one but the sound is not working properly
Check your settings:
On XP:
Go to Control Panel, select Sounds and Audio Devices
Double-click on it and select "Hardware" tab
Select the sound device and click "properties" button
Select "Driver" tab and update driver.
On Vista:
Go to Control Panel >click Hardware and Sound
Select "Sound" > click "manage audio device"
Highlight your sound driver then right click to Properties
Under the Controller information click Properties button
Select "Drivers" tab
Select "Update driver"
Jan 11, 2009 | Acer Aspire One PC Notebook
Sound problems
well, the driver is not installed properly.. you must install it first so that u can use your cam.. f installed already, check your connections and make sure your cam is detected by your computer
Nov 14, 2008 | Acer Aspire 5315 Notebook
0xC00D11BA
nese sito los drive del sonido y me da este erro por que no tengo los draiver que puedo aser
Jul 04, 2008 | Acer Aspire 3000 Notebook
No Sound from Acer 5100 : Volume tab is disabled
I am worried that there is a problem with the sound card on your motherboard. If it has worked in the past and then suddenly disappeared, usually it is because the computer can no longer locate your sound card. It will not load a driver for a device that no longer exists. Since you have already done most of the troubleshooting steps, it is time to think about replacing your motherboard. Good luck
Apr 24, 2008 | Acer Aspire 5100 Notebook
Acer aspire 4315!
It sounds like you have not properly installed the audio driver. You have to go in device manager and see if you have any question mark in any of the devices or the audio. To go to device manager you hit start then control panel and then click device system and then click device manager.
Jan 16, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
